Steering column removal
Old May 25, 2007 | 06:17 PM
aperfectcircle's Avatar
Car: 91 Camaro
Transmission: 700 r4
Axle/Gears: stock, soon to change.
hi, im installing a new steering column due to vandals..
its a 91 Camaro.. is there any tricks or anything i'll have to do to get the old column out??
thanks!
Old May 25, 2007 | 06:27 PM
j dezzy's Avatar
Car: 87 TA
Re: Steering column removal
no tricks, it's pretty straight forward. once unbolted it should just slide rightout. If you have an airbag make sure to pull the fuse and carfully remove it from the steering wheel first. you don't want that going off in your face.
Old May 25, 2007 | 06:35 PM
Car: 91 Camaro
all right cool. thanks for your help!
Old May 25, 2007 | 06:37 PM
j dezzy's Avatar
Car: 87 TA
good luck
Old May 27, 2007 | 08:00 AM
Steve86TA's Avatar
Car: To many to list
Dont forget about your VATS system though.The new column probably wont be the same resistance so you will have to address that.As far as removal,1 15mm nut in the engine bay on the steering shaft,3 10mm holding it to the firewall and 2 13mm holding it the the dash.Then there area bunch of plugs and the shifter cable.Not a bad job at all.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Oenone
Aug 29, 2015 07:54 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
