Question about AutoMeter trans temp gauges
Old Jun 14, 2007 | 09:42 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Which one is easier to set up on a 700R4, the electrical or mechanical guage? Or is there only one that works?
Old Jun 14, 2007 | 11:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Question about AutoMeter trans temp gauges
Do they make a mechanical one? Either one would be about a similar effort to install as the other.
Old Jun 15, 2007 | 05:45 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
the electrical one is easy, tap a sender into your pan or adapt it to your line with brass fittings and hook up the sender/wire to the gauge.. I didn`t even know they made a mechanical one either but if it is like a mercury line type, I could see that being a pain with spring covered line that you can not cut
Old Jun 19, 2007 | 06:45 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
The sender for the eletrical guage screws right into the test port on the left hand side of the tranny. Just unscrew the plug and screw in the sender, no drilling required.
Old Jun 19, 2007 | 06:51 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well I had a trans, engine and coolent temp gages mounted (just for testing) in my car at the same time and road around for a month before I realized that the trans and engine oil temps were always very close to the coolent temp. Now if your towing that s another story.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
gta power
Aug 13, 2015 06:15 AM
