Turn Signal only works one way?
Old Jul 3, 2007 | 11:37 AM
89jim's Avatar
I have an 89 GTA and when I turn left the turn signal clicks down and everything is fine. If I need to go right the lever can be pulled up hard and the signal works but you have to hold up on it or it just snaps back down. It's a pain. Should I take off the wheel or what? What holds the lever in position until you turn? It feels like it is under pressure.
Old Jul 3, 2007 | 01:55 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Turn Signal only works one way?
most likely the turn signal cam assembly is cracked it happens often, youll have to remove the steering wheel and lock plate and then there will be the turn signal assembly
need a wheel puller and lock plate compressor, borrow one from a shop or friend or buy them they are 15 bucks each, or rent for free at auto zone
good luck
Old Jul 3, 2007 | 02:18 PM
89jim's Avatar
I have a wheel puller and will get the plate compressior.Where do I get the replacement cam? Is it a dealer item?
Old Jul 8, 2007 | 07:12 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
You might be able to find one in the Motormite HELP! section at your local Pep Boys, can't remember if we still carry them or not. Otherwise, they're about $0.50 at the dealer.
Old Sep 9, 2007 | 11:30 AM
Tony88GTA's Avatar
Car: 88GTA
Engine: 5.7
I just had the same problem. Pulled the wheel and it ended up just being a lose screw on top of the cam.
specialized
Jun 18, 2022 09:26 AM
Caspar
Jun 19, 2016 11:19 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
