auto windows to manual
Old Jul 6, 2007 | 08:34 AM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
i am interested in getting manual windows and am wondering what you need and is it a difficult and expensive process.
Old Jul 7, 2007 | 09:44 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: auto windows to manual
why? i had manual windows, i swapped to power.
but if you insist, you need to drill out the rivets and replace the window regulator with a manual one, then drill a hole in your door panel for the crank.
Old Aug 26, 2007 | 07:52 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Hey stevenb any luck with this swap yet I am trying to do this now and my drivers side is giving me a hell of a time. any tips.
Old Aug 26, 2007 | 09:51 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I sold a set of manual regulators to another member last week and still have 1 set left. $40 + shipping. This swap is pretty easy, the hardware I usually use to install the regulators is 4 short 10MM nuts bolts.
BlueBeast
If you install a window regulator in the wrong holes it will cause significant adjustment problems once you try and raise the windows up. As long as you use the correct mounting holes any adjustments will be minimal. (You probably will not need to adjust anything if they are in the right holes !! )
with Power Windows - The rivets holding the regulator in place are located in the holes closest to the FRONT of the car.
with Manual windows, The 2 rivets holding the regulator in place are located in the holes closest to the BACK of the car. (See yellow circles) The other 2 mounting holes will line up with the right holes once the front 2 are in the right place. ( red circles )
If I remember right you can only install 2 bolts/nuts with the winodw down.... the other 2 holes are more easily accessable once the window is raised.
Old Aug 26, 2007 | 11:13 PM
MNformula350's Avatar
I converted my Formula to manual windows, it took about 15 minutes per door. Swapped regulators, cut an X in the cloth for the manual crank, and that was it.
Old Aug 27, 2007 | 03:37 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
I couldn't belive I was having as mush trouble as I was. It seems so basic and straight forward. I am going to try again tonight so I hop[e atleast the drivers side is done. I am having someone hold the window up while I get the manual reg. into place and then trying to get something in any of the holes. I'll let you guys know how it goes.
Old Aug 27, 2007 | 05:54 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
ok guys this is driving me insane. This is what I am doing to get these man. regs. in. I am having someone hold the window up and I am trying to slide in the man. reg and put the slides into the tracks. When I put the slides into the track and try to get it to line up with the holes in the door the window is not right. Now I have no idea if the reg is in the right spot meaing in the up postion or the down postion, but I have tried both. I have also tried both sides of the man regs. I am going to post pics of everything I am working with. I thought maybe that I have man regs for just one side of the car but they look differnt to me. I have also held up the man reg to the power reg and have come up with what i thought is the correct side. What am I doing wrong. Here are the pics.
So this last one I think is the correct side for the drivers. That is the drivers side power reg. The passenger side is still in the car so I know that is the drivers side.
Old Aug 27, 2007 | 06:41 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Hey John can yo post pics of the ones you have. I want to see if mine are the right ones. Are the man. regs. the same for all the years?
Old Aug 27, 2007 | 10:00 PM
John in RI's Avatar
I just looked at the picture of the regulators I sold and I can't tell which is which without checking it (about 3 times) first. I'm just to tired to do that research right now !
Since your already involved in the project - take off the passenger side door panel. Match up the regulator on that side and then put the "matched" passenger regulator in the garage until your ready for it. Then try installing the drivers side regulator. Compare it to the drivers side power regulator and be sure that the manual regulator in in the "DOWN" position when you start.
When your installing the regulator raise the window all the way up to get the regulator in - and then lower it all the way before installing the rollers in thier tracks. Be sure you are putting the rollers in the correct tracks !
Also take notice of the square 'notch' in the door that is made specifically to hold the regulator in place. ( Power or manual. ) It's visigle in the very center of the picture i posted. Once all the rollers are in the tracks stick your arms inside the door and adjust everything until the regulator sits properly on the notch.
Old Aug 29, 2007 | 06:13 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
I just wanted to say thanks guys I finally got the drivers side in and working. The passenger side will get done this weekend. Thanks again.
Old Aug 29, 2007 | 06:33 PM
John in RI's Avatar
Nice to have working windows again -----> Ain't it !!!!!
Old Aug 30, 2007 | 08:11 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
I just want to say thanks again I have both doors done now. All I have to do is the doors panels, hopefully I wont mess the custom panels up. Anyone know how big of a hole to make for the cranks? I had the passenger door done in about 45 mins. I couldnt belive it. Thanks.
1992 Trans Am
May 10, 2023 07:19 PM
86CamaroDan
Sep 29, 2015 10:08 PM
angel2794
Sep 8, 2015 06:22 PM
hepcat620
Sep 2, 2015 11:51 PM
stalkier
Aug 21, 2015 01:54 AM
