Headliner w/ overhead console questions
Old Jul 6, 2007 | 08:59 PM
briwar454's Avatar
Car: 1985 Trans Am
Transmission: THM 700-R4
Axle/Gears: Stock
hello hello, i'm a few months away from replacing my t-top headliner. i'm thinking of buying an abs headliner from hawks. will this work with my overhead console? will i have to do a bunch of cutting?
as always, thanks for you time!
Old Jul 6, 2007 | 09:27 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Headliner w/ overhead console questions
Yes it'll work, and yes you'll have to do some cutting.
I have a tech article that shows every step here:
http://www.iroczone.com/technical/headliner
Old Jul 6, 2007 | 09:37 PM
briwar454's Avatar
Car: 1985 Trans Am
Axle/Gears: Stock
is it crazy hard to cut into the plastic? i'm a total novice.
Old Jul 9, 2007 | 08:03 AM
Jim85IROC's Avatar
It's hard for me to say. For me it was a piece of cake, but this wasn't exactly my first time cutting ABS. If you take your time with your dremmel, I really don't see it being that hard even for a novice. While it may ultimately take longer, it's vitally important that you cut a little on the small side. If you cut too big you're screwed, but if you cut a little small, you can always re-cut it larger. I cut mine a tad small, then did additional trimming to make it fit.
Old Jul 9, 2007 | 04:11 PM
briwar454's Avatar
Car: 1985 Trans Am
Axle/Gears: Stock
thanks man! i just needed the emotional support!!
Old Sep 9, 2007 | 11:53 PM
Sean7531's Avatar
Is the ABS worth the cost for replacement or only if you need a new board. I can get the headliner re-done for $125... The guy already looked at it and said the board is still in decent shape. I'm in the same predicament, I can see myself buying the ABS and destroying it and still paying the guy $125!!
Old Sep 11, 2007 | 07:24 PM
briwar454's Avatar
Car: 1985 Trans Am
Axle/Gears: Stock
my headliner was falling apart. i would have recovered it if the headboard was in good shape.
Old Sep 11, 2007 | 09:49 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
the headboard is never in good shape, 20yrs of heat cold and humidity just makes fall to pieces.
Old Sep 12, 2007 | 06:32 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
when I re-did mine in my 88 IROC the headliner board was in terrible shape it broke in two peices upon removal. I used some 3M spray adhesive and some fiberglass cloth, and it worked fine. The fiberglass cloth stuck out a little bit under the fabric, was only noticeable by touch. If your looking to save money total cost for new fabric, spray glue and fiberglass cloth was around $30-$40 being that the new fabric costs like $10 a yard and it took 3
Old Sep 12, 2007 | 07:35 AM
skiwrench's Avatar
Car: 2015 Chevy SS
Engine: LS3
Transmission: 6L80E
Cutting the ABS is no problem. I recently did my headliner which was pretty complicated because I have C&C t-tops. What I had to do was buy an uncovered ABS hardtop headliner, install it, mark where the t-top openings were, and cut out those sections. The cutting took me about an hour using a dremel with heavy-duty cutting discs. If you go the route of the dremel I would recommend using one of the lower (if not the lowest) speed settings because otherwise the disc will get too hot and the ABS will melt!
Also, covering the headliner is not hard, I had never done anything like it before but I was amazed at my professional-looking results. Just go slow and use brand-name (3M) adhesive. I hope that helps!
Frozer!!!
Jan 19, 2024 04:55 PM
Veaceonee
Sep 29, 2016 08:15 PM
MORREALE5
Sep 13, 2015 09:01 PM
Victor6
Aug 30, 2015 02:09 AM
TheJoeY88
Aug 13, 2015 06:51 PM
