Cluster question...
Old Jul 9, 2007 | 04:57 PM
napalmrules's Avatar
Car: 84 camaro
Engine: 305 v8 4bbl
Transmission: stock
Axle/Gears: stock
Cluster question...
Hi everyone, I'm new here and hope this is the right place for this question..
I bought my baby a few months ago and am now looking to start changes after reading some of the stuff on here, you guys have excellent info!!
I have an '84 camaro that unfortunately comes with the wonderful dual needle instrumentation... um, no. I would like to change this to a different speedo and clustering if possible...i really like the 145 speedometer but i would settle for the 115 if necessary...my main question is basically can i swap the whole cluster out, or do i need to do it piece by piece? i would like to just put the whole cluster out of a later third gen if possible, can anyone point me in the right direction on this?
here are my specs, per vin check
Year: 1984 Style/Body: Coupe 2D Make: Chevrolet Engine: 5.0L V8 4BBL Model: Camaro Base /Z28 Country of Assembly: United States
it is the coupe, not the z28 model....
btw, i know my brake light is on...
Old Jul 9, 2007 | 05:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Cluster question...
You can swap in an 85, 110, or 140 from a cable-driven Camaro up to 89. I'd suggest simply swapping in a newer speedo head into your cluster; occasional electronic problems crop up otherwise. If you're interested in a 140, I have one with a working trip odometer (though the speedo itself jumps two or three miles per hour over 70). If you're interested, please PM me.
JamesC
Old Jul 10, 2007 | 08:07 AM
Car: 84 camaro
Engine: 305 v8 4bbl
Transmission: stock
Axle/Gears: stock
thanks for the info...
pm sent
Old Jul 10, 2007 | 09:40 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Holy crap! An '84 with only 22k miles?
Sweet.
Welcome to the forum.
Old Jul 17, 2007 | 08:47 AM
IROC-Z_Racing's Avatar
Car: 89 IROC-Z28
Engine: LS1 "ASA"
I have an 89 IROC with a speedo of 115 which sucks! JamesC, you said that changing out the WHOLE cluster could possibly bring up electronic problems, how so? Can I just replace the speedo gauge and be done with it, or is there recalibration that needs to be done by either computer or tensioning?
Old Jul 17, 2007 | 09:23 AM
JamesC's Avatar
Originally Posted by IROC-Z_Racing
JamesC, you said that changing out the WHOLE cluster could possibly bring up electronic problems, how so? Can I just replace the speedo gauge and be done with it?
I've sold several clusters where various electronics problems cropped up after the swap. It seems easier, if you know your original cluster functions as it was designed, to swap the new speedo head into your old cluster, thus eliminating potential problems. Aside from the swap, no other calibration is required. You might take a peek at my trip odometer fix in the FAQ section (as about 90 percent of them are broken):
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Jul 17, 2007 | 10:57 AM
Car: 89 IROC-Z28
Engine: LS1 "ASA"
All I can find is clusters. Can I buy the cluster and take out the speedo and put it in? The reason I'm so concerned with it, is that I've read a lot about people who have changed the entire cluster and the new one doesn't work, so then they put the old one back in, and now that one doesn't work. So I'm just trying to get it right the FIRST time and not have problems. Thanks for the info above!
IROC-Z Racing
Old Jul 17, 2007 | 03:12 PM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
Sweet.
maybe it's 122k miles
Old Jul 17, 2007 | 03:46 PM
JamesC's Avatar
Yes, that's what I'm suggesting.
JamesC
Old Jul 17, 2007 | 05:42 PM
Car: 89 IROC-Z28
Engine: LS1 "ASA"
JamesC
Thank you!
Elephantismo
Feb 13, 2019 12:51 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
