Anybody use the aftermarket door top plastics available from Hawks?
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I'm thinking about buying these but before i drop close to $200 I'd like to get some input. Any experiences?
http://www.hawksthirdgenparts.com/in...ROD&ProdID=569
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Re: Anybody use the aftermarket door top plastics available from Hawks?
I bought 'em. Don't like 'em. Wouldn't recommend 'em! Try and find a good used set.
Car: 87 GTA
$200 for 2 pieces of plastic???? They are making like $150 profit! NO WAY that plastic cost them near $200 to make.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I simply searched the yards until I found two that were in good shape. The cost was nowhere near $200.
JamesC
JamesC
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
thats crazy. maybe, maybe if it was GM. maybe. highly unlikely, but maybe.
aftermarket, no way...
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I found a pair in good shape at my local junkyard. Paid $10, cleaned them up and put a coat of SEM flexible coating type paint, they look like new. I removed the weather stripping, and will reattach it later when I put it in the car.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
My trouble is that they always seem to be warped, and the weatherstripping that is attached to them always seems to come off and bend, and then I can never restore that.
Car: 1985 Trans Am
Transmission: 700-R4
im pretty sure classic industries sells the inner pieces for aroun 45? I paid $90 for inner and outter, but the outter dont fit very well....will never buy from classic again
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Back to the original question. I installed a set from Hawks on a T/A, and they looked and fit great. My only complaint was that the studs for holding the door panels weren't long enough, and took some effort to get the retaining rings (new, included with door tops) on. However, I had new door panels at the time as well, so they might have been thicker than original panels.
It sounds like there are cheaper options, I just don't have experience with them.
It sounds like there are cheaper options, I just don't have experience with them. Member
It sounds like there are cheaper options, I just don't have experience with them.Joined: Aug 1999
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
FWIW, I just installed both inner and outer on both doors, purchased
from 1aAuto from a recommendation here on the boards..
http://www.1aauto.com/1A/Weatherstri...SS00097/305147
is the interior pair, but you can get singles, outers, inners, or all as you need.
Quality and my experience with them was great.
mike
mike
Car: '85 TA
Yep, moulded studs. A little tough to get the metal clip on (this is one of the only pictures I have, and it's not on all the way) but once it was on, you could push it down and squeeze with a pair of pliers to help tighten the "jaws", and it worked fine.
JamesC
Car: '85 TA
Yep, the OE was a nut as well, but they included these retainers (pain in the rear to get on at times).
I assume removing them would be unpleasant too.
JamesC
JamesC
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
They are down to $169 but no way would I pay it at this point. Thgere are too many good ones at the junkyard. I guess I will bring a few home and store them for the future.
1992 Trans Am
May 10, 2023 07:19 PM
