Roll cage
Old Jul 24, 2007 | 10:06 AM
texan_rebel's Avatar
Car: 1989 RS camaro
Engine: 350Ci
Transmission: TH-350
Roll cage
I tried searching and couldnt find a answer but other than saftey of a roll over does a roll cage help stiffing the cars frame, or is it just for a roll over?
Old Jul 24, 2007 | 10:08 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Roll cage
these cars dont have frames..
but yes, a roll cage does significantly make the car stiffer.
Old Jul 24, 2007 | 10:14 AM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
Re: Roll cage
almost a must if you want 450-500 rwhp. the fbody twist so much it's not even funny. my old 86 Iroc with a mild 355 ripped the roof at the b piller.
Old Jul 24, 2007 | 10:45 AM
Car: 1989 RS camaro
Engine: 350Ci
Re: Roll cage
I know the car has a sub frame but other than that not too much support but i didnt think a mild motor would twist the car that much, i wanted to put a 6 point in now looks like thats next weekends project thanks guys
Old Jul 24, 2007 | 11:43 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: Roll cage
I put a six point competion enginering cage in my car. I am really happy with the fit. Also the chassis is alot stiffer. I havent driven it but can tell when jacking up the car. The only thing is your back seat becomes useless. But hey if you don't have to sit back there then who cares. I also like haveing the 5 point harness.
Old Jul 25, 2007 | 01:32 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Roll cage
i put a cage in my car when i was only in the high 12's.. did it so the t-tops stay nice and comfy and because i'm plannin on runnin 10's eventually..
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
FueledSoul
Sep 30, 2015 09:18 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tmork454
Sep 29, 2015 06:33 PM
