86 Firebird Shift knob removal
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
86 Firebird Shift **** removal
I have searched this site on how to do this but i can only find it for camaros and i dunno if its different at all.
So basicly the leather on my automatic shift **** has a nice hole in it that seemed to come out of no where
So 2 things...how do i get this old one off so i can put a different one on...and where can i buy an OEM replacement or a direct fit aftermarket one.
Thanks guys
So 2 things...how do i get this old one off so i can put a different one on...and where can i buy an OEM replacement or a direct fit aftermarket one.Thanks guys
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: 86 Firebird Shift **** removal
Thanks guys
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
X2. Also alot of floorshift GM models attach the same way. A GrandPrix is a polular one, S-sereis, J-bodies, Fieros, Some Olds, Etc
Axle/Gears: 3.45, 3.27, 3.27
Put the shift lever in 1st gear and you'll be able to look over the top of it to see the slot where the U-shaped clip is licated. Use a small flat blade screwdriver to get the clip out. Once the clip is out the **** slides right off the lever.
Lon
Lon
Engine: 305 5.0 LG4
Thank you all for the quick reply and advice it was much appreciated.
Just one more dumb question...is there any specific way to put the clip back in. So i dont damage it
Also if you lose it, you can make another one out of a paperclip.
Not a very high tech part. Joined: Jan 2004
Axle/Gears: 9-bolt/3.45
Here's where you can get a new handle:
http://www.moderndaymuscle.com/inc/sdetail/920
And if you lose or damage your clip during the process:
http://www.moderndaymuscle.com/inc/sdetail/645
Engine: 305 5.0 LG4
1992 Trans Am
May 10, 2023 07:19 PM
dhonda200
Aug 11, 2015 11:50 PM
