colored steering columns
Old Aug 14, 2007 | 01:15 PM
bd_slim's Avatar
Car: 89 iroc vert-91z-28
Engine: 305 tpi-305 tpi
Transmission: 700r-4-700r-4
Axle/Gears: 3.23 posi-3.73 posi
i was calling around junkyards looking for a steering column and one said that they had a grey one and a red one. i guess i didn't know that they came in colors other than black. anyone have any pics of the colored ones?
Old Aug 14, 2007 | 01:37 PM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
Re: colored steering columns
i know the 2nd gen fbodys had colored column. i thought the same as you all third gens where black.
Old Aug 14, 2007 | 02:06 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
I'm not aware of other colours in the Camaros, but not just the Camaro's used that particular steering column. Many other GM/Chevy vehicles used the same one. And they came in all kinds of colours (Red, Grey, Black, Blue, etc). The '80's S10 & S15 trucks and Blazer's/Jimmy's had the same one for example. The only differences was the wheel style and how long the steering shaft extended. The ignition set-up, tilt feature, the multi-function stick (with the cruise, blinkers, washer/wipers, etc) were also all the same.
Maybe they were referring to any column that was compatible with your ride?
Old Aug 15, 2007 | 01:38 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
sounds pretty cool, I'd like to see a colored one installed...
Old Aug 15, 2007 | 02:01 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I want to see one with a matching dash pad. That too only came in black. I did see a tan dash pad once tho. It too was interesting.
Old Aug 16, 2007 | 04:20 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
They were referring to matching columns. I believe C4's without the telescoping column had the same column as well. My remanufactured column was sandblasted and rattlecanned, then I subsequently scratched it with my column lock. Oh, sad times.
Linson
Sep 21, 2015 01:08 PM
383cam
Sep 9, 2015 06:01 AM
angel2794
Sep 8, 2015 06:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
