Tach problems 91 RS
Old Aug 23, 2007 | 04:44 AM
mknopp's Avatar
Tach problems 91 RS
My tacho reads very high at idle it sits at about 3500 and at a medium to full rev the needle is hard against the stop. I have replaced the complete cluster and I have replaced the distributor I have also checked the wiring between the distributor and the tacho WHAT more can I look at?
Old Aug 23, 2007 | 04:38 PM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
Re: Tach problems 91 RS
more than likely your tachs are no good, I've had the same problem. apparently someone figured out how to fix it by soldering in a resistor
Old Aug 26, 2007 | 03:00 PM
mknopp's Avatar
thanks redfire, I might try fixing my old tach as parts for camaro's are a bit hard to get in New Zealand
Old Aug 28, 2007 | 12:53 AM
Purple 92 SS's Avatar
Car: 1992 Z/28, 2000 SS, 1968 RS/SS
Engine: 355 Built a bit / LS1
Transmission: T-5 / A4
Axle/Gears: 4.10 / 2/73's
https://www.thirdgen.org/forums/elec....html?posted=1
see that thread. ive done this now to 2 cars, and both work fine. I highly recommend it.. It is simple 2 100k resisters at Radio shack is what i got.. cant beat it.. cost me all of 99 cents to do 2 of them.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
