removing the center console/shift knob
Old Aug 23, 2007 | 08:08 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
removing the center console/shift ****
ive been ripping apart my interior got everything out but the console and a little carpet, i got the two screws near the window switches, the 2 inside the console, where else are there screws? And how do i take off the shift ****? The car is an 85 ta thanks!
heres a pic...
Old Aug 23, 2007 | 08:22 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: removing the center console/shift ****
When I removed the shift **** off my 92 there was a clip in the front of the **** about halfway down that you just pulled out and the **** slides right off. It may be different on your 85 though, not sure.
Old Aug 23, 2007 | 08:27 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
My 87 Camaro also just had a little clip in the front of the shift *** that I just popped out with a screw driver. I had to take out my cd player and heater/AC control unit to get the upper console out on mine. The console is different in a Camaro though, so I am not sure on anything. Have a look at the pieces around your cd player for any screws.
Old Aug 23, 2007 | 08:44 PM
Celticsfan's Avatar
Car: 1985 Trans Am
im gonna go check that out on the shift ****...thanks
Old Aug 23, 2007 | 09:01 PM
Celticsfan's Avatar
Car: 1985 Trans Am
ya that bitch isnt coming out easy, im uploading pics from my phone, im stumped
http://i11.photobucket.com/albums/a1...g?t=1187921869
Old Aug 23, 2007 | 09:59 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Hard to tell from that pic, but it looks like the same kind of clip that was on my ****. It was kind of tough to get out, but I just kept prying it out with a screwdriver and it eventually came out, then just slip the **** off.
Old Aug 23, 2007 | 10:05 PM
Celticsfan's Avatar
Car: 1985 Trans Am
yup...searched it, pulled it out and im good, the console is pretty loose but still doesnt want to come out...its 11 here so im done workin...but i dunno why its not comin out...i need to get that piece of carpet out
Old Aug 24, 2007 | 09:45 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
if i remember right there's a screw either under the ash tray, or you have to pop the shifter plate off and it's under there by the ash tray. Been awhile since I parted out a Firebird.
Old Aug 24, 2007 | 11:24 PM
redfirebirdman8's Avatar
Car: '89 Trans Am
Engine: 305 T.P.I.
Axle/Gears: 10 bolt 3.73’s
yep theres 2 in the ashtray.
Old Aug 25, 2007 | 12:22 AM
Celticsfan's Avatar
Car: 1985 Trans Am
im pretty sure i got the two in the ash tray because theres two holes where screws should be...must have not put them back the previous time...but it seems like its stuck where the e break is.
Old Aug 25, 2007 | 01:17 AM
Car: '89 Trans Am
Engine: 305 T.P.I.
did you take the ebrake handle off? thats the only thing i can think of that would hold it on there. make sure you got all of them, including the two at the back of the console. in the inner compartment.
Old Aug 25, 2007 | 01:33 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I'm not sure if you caught it, but you have to remove the shifter plate to access the final screw. Then pull up the e-brake, and pull the whole console up...
Old Aug 25, 2007 | 09:28 AM
Celticsfan's Avatar
Car: 1985 Trans Am
ya i got the 2 in the console, how do i take off the e break handle? and yes the shifter plate is off
Old Aug 25, 2007 | 01:32 PM
Celticsfan's Avatar
Car: 1985 Trans Am
well i got it off, not completly but enough, i ended up buying some rustoleum rust prevantative paint, i sanded it, vaccuumed it and coated it, sorry no pics yet cam battery is dead
Old Aug 25, 2007 | 06:16 PM
Car: '89 Trans Am
Engine: 305 T.P.I.
theres a phillips head screw on the side facing the drives seat.
Old Aug 25, 2007 | 09:53 PM
Celticsfan's Avatar
Car: 1985 Trans Am
ya i got that off, but w/e its all set now, ill hopefully get some pics tomorow...
TheExaminer
Sep 6, 2015 11:40 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
