4th gen rear seat question
Old Sep 9, 2007 | 04:33 PM
Gutz's Avatar
Car: 89 GTA
I just swapped in 4th gen seats and noticed in the back seat at the top of the hump there is a bar on either side you can see know.What have you guys done with this to hide it?
Old Sep 9, 2007 | 08:13 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: 4th gen rear seat question
Originally Posted by Gutz
I just swapped in 4th gen seats and noticed in the back seat at the top of the hump there is a baron either side you can see know.What have you guys done with this to hide it?
Brother WTF is a "BARON"
Old Sep 9, 2007 | 08:21 PM
ssean92's Avatar
Car: sold
I understand what baron is, but I don't have that issue
Stephen's Avatar
Car: 87 GTA
Barren, as in dead space.
When I did that to my 92, I didn't do anything. In fact, I've never seen anyone do anything.
The dead space is so minimal, nobody will notice it, unless you point it out.
Old Sep 9, 2007 | 10:51 PM
Gutz's Avatar
Car: 89 GTA
It was supposed to be a bar(round piece) on each side where the old seats swiveled on.You can't see the drivers side but you can see the passenger side.The back rest doesn't come down far enough to cover the little bar on the passengers so I was wondering if anybody else had this problem?
Old Sep 9, 2007 | 11:09 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Apparently your car originally had the "split folding" rear seat in it. Since the 4th gens only used a 1 peice rear seat backrest this bracket is now exposed.
You can just get a spot weld drill bit and drill out the spot welds so the bracket can be removed.
Old Sep 9, 2007 | 11:39 PM
Gutz's Avatar
Car: 89 GTA
Thanks ,i'll pull the carpet this week-end and remove the bracket.
Old Sep 10, 2007 | 03:16 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i was going to suggest the removal to because i had split seats and now i have 4th gen seats
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
z28addict8490
Aug 7, 2015 08:48 PM
