Changing speedo cluster from 84 to 87 having problems
Old Sep 16, 2007 | 04:50 PM
Dave Staacke's Avatar
Trying to see if you ever run into this problem or know somebody who has,I have a 84 trans am trying to put newer model instrutement panel in instead of old one,one problem i have is no speedo cable hookup,also when i set it in place and turn lights on they basically goes heywire,do i need to change out the dash wiring out also,then what do i do about speedo,thanks,any help will help.
David
my email is dlstaacke@yahoo.com i need help
Old Sep 16, 2007 | 04:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Changing speedo cluster from 84 to 87 having problems
The 84 used a cable-driven speedometer and the 87 had an electronic one. You'll need to put a VSS in the transmission and wire it to the speedometer.
Old Sep 16, 2007 | 05:59 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Here's another Answer,..........
https://www.thirdgen.org/forums/inte...ml#post3467673
Jeremys87
Jul 14, 2022 09:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
