autometer gauges cluster and wireing harness question
Car: 85 camaro z28
Transmission: auto to manaul
i see they make an autometer guages cluster and wiring harness kit for our cars, does that mean i wont have to cut any wires?????
http://www.ecklerscamaro.com/product...dept%5Fid=1648
http://www.ecklerscamaro.com/product...dept%5Fid=1597
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Re: autometer gauges cluster and wireing harness question
Looks to me like that second one has everything to bolt right up except for the speed sensor. Those things are freaking expensive, they do look very nice though.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
It is a dash with gauges from Covens Classic. I put the link below. Yes it is a plug and play unit. The built in harness makes it real simple. The panel and gauges come in different finishes. Buy direct and save $30.00!
http://www.covansclassic.com/parts/d...64.231.135.174
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
covans?
I'd save some cash and get the jimmy jams gauge panel, i personally think they look a little better.
Car: 1987 Iroc-z Convertible
I would rather use the stock face trim and an empty cluster then just use a pillar for the oil pressure. Where is the turn signals in that one?
Car: 89 Camaro RS
Yeah, I really like the Jimmy Jams unit. I have there auto shifter switch panel, and I love it. They do some quality work over there.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Car: 85 camaro z28
they dont have a space a check engine light, do they?
If you really wanted a engine light you could probably make a hole for a led indicator light. Wouldn't really worry about it though.
I'm torn between aftermarket gauges and stock gauges. I like both, and my original speedo is broken soooo? hmmmmm.! lol!!
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
tooo pricy for those use to stock panel and just take the stock gauges out and pop in the ones of ur choice! Thats What I did! I got the 5 inch tach and speedo too..
If you have questions about mine please check my thread I made in the section as I explained it a bunch of times!
Jay
Jay
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I seem to recall that a few months ago, John Nelson of Chevy High Performance installed one of these clusters in an 84 Camaro (IIRC). At that time some modification of the harness was required. I e-mailed Covan for further info moments ago. Should the cluster truly be plug and play, I'd be very interested.
JamesC
JamesC
Here's the response from Covan:
None of our wiring is direct plug to your factory wiring. You will be taking your factory plug off then putting your factory wires into the new plugs we provide so you can still plug into the new gauges. Thanks!
Abbie Anglin
Covan's Classic, LLC
6020 Parkway North Drive
Bldg. A, Suite 300
Cumming, GA 30040
1-866-882-3525
Abbie Anglin
Bldg. A, Suite 300
Cumming, GA 30040
1-866-882-3525
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Do you know a website for firebird/trans am gauge clusters like that?
Car: 1985 Trans Am
Axle/Gears: 3.70
Car: 89 Camaro RS
www.jimmy-jams.com Click on thirdgen items or something like that. Then scroll down and its near the bottom of the page. Its only $55 and it is a qaulity piece.
