Rear seat belt reciever stuck
Old Oct 21, 2007 | 02:41 AM
capt07's Avatar
Car: 86 Sports Coupe
Engine: 2.8L V6
I am removing my entire interior on my 86 Camaro and I ran into a problem.
The rear seat belt catches are seized on. I was using a large hex tool on my fronts with no problem but the same one almost stripped the back two. I stopped b4 it did strip as I don't have a torx that freakin' big.
Anyone run into this problem? I just cut the rug around it to remove the carpet. But when I do get new carpet I want those out for easier installation.
-Paul
Old Oct 21, 2007 | 02:57 AM
capt07's Avatar
Engine: 2.8L V6
Re: Rear seat belt reciever stuck
Here is a pic
Old Oct 21, 2007 | 09:59 AM
Bandit5's Avatar
I usually drench them in PB Blaster and let it soak in for a few hours. Then I come back with a ratchet or breaker bar and put ever increasing pressure on it. Keep the torx bit in, and just slowly increase how much force you are putting on wrench. It can take several minutes, but eventually, they will come loose.
Old Oct 21, 2007 | 11:40 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
buy a set of torx bits , you will be glad you did . good penatrent , proper tork bit , ball peen hammer , spray underneath , time & patience you'll get it out .
massage bolt head wiyh ball peen , [ don't mess up head ] tap torx bit back into bolt head every once in awhile to keep from deforming .
Old Oct 21, 2007 | 01:58 PM
capt07's Avatar
Engine: 2.8L V6
What size is the torx? mine don't go that large.
Old Oct 21, 2007 | 02:07 PM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
47 or 50 I forget
Old Oct 21, 2007 | 02:10 PM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
put a longer piece of pipe on the wratchet for leverage , makes it easier to break em free.
Old Oct 21, 2007 | 03:18 PM
capt07's Avatar
Engine: 2.8L V6
OMG! I have lived in OK way too long! "don't go that large" What was I thinking!!!! My HS english teacher would kill me!
Old Oct 21, 2007 | 06:10 PM
UNCLE TOM's Avatar
not sure but i think its a #50 . buy a set , a man can never have too many tools . aaarrrrrgggghhhhh .
Old Oct 26, 2007 | 07:39 PM
thewolf's Avatar
Car: 1984 Pontiac Trans Am
Engine: LG4 305 V8
Axle/Gears: 10-bolt LSD
The size you are looking for is Torx 47 or T-47. Don't use a hex key, allen key, or hex end socket on a torx bolt. You will strip it!
The T47 is hard to find. After breaking several cheapies, I bought an SK socket from Amazon.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
