91 HVAC questions
Old Oct 22, 2007 | 08:00 PM
mnmattie's Avatar
91 HVAC questions
Are the HVAC controls completely vacuum operated or does it use rods/cables? I can't switch the vent position, and haven't taken it apart yet. Thanks guys!
-Mattie
Old Oct 22, 2007 | 09:52 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: 91 HVAC questions
I believe they are vaccum controlled. They are the same things as the pre-91 style, just with yellow letters instead of white.
Old Oct 22, 2007 | 10:09 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
The hot/cold flapper is cable. All other flappers are vacuum actuated. And of course fan speed is electric.
Old Oct 23, 2007 | 05:00 PM
mnmattie's Avatar
So to get rid of the yellow lettering, I would need to swap in an 88-89 HVAC unit?
Could installing LED's help change the color?
-Mattie
Old Oct 23, 2007 | 08:19 PM
You can remove the faceplate and just swap in one from an older car with white letters. pull the **** and the little slider buttons off and the faceplate unscrews from behind.
Old Oct 24, 2007 | 02:28 AM
mnmattie's Avatar
AWESOME! I'll hit the yards tomorrow!
-Mattie
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Casey Meyers
Mar 2, 2016 10:46 AM
777Shock777
Oct 29, 2015 04:30 PM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
redmaroz
Aug 16, 2015 11:40 PM
