autometer gauges question
Old Oct 28, 2007 | 09:24 AM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
if i install the autometer gauges and breezle, how do i bypass the vss in my 85 camaro. i will be using a electric tach with the elctric sensor but with out the cable?
Old Oct 28, 2007 | 03:49 PM
MNformula350's Avatar
Re: autometer gauges question
An 85 Camaro , should have a Speedometer Cable, not a VSS
Old Oct 28, 2007 | 06:13 PM
jayk2k3's Avatar
Car: 85 camaro z28
it does, im trying to eleminate the cable and go electric
Old Oct 28, 2007 | 07:08 PM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
doesn't autometer still have the adapter for the electric speedo?
Old Oct 28, 2007 | 08:50 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
What engine do you have? If you have an ECM there should be wires coming off the transmission that are your VSS wires going to the ECM you could tap into those and run them to your speedo. I can't remember what year they started putting the VSS on the transmission though. If Autometer doesn't make an adapter you might have to change your tailshaft housing.
I'm not a hundred percent on this, you might want to do a search as I'm sure your not the first to attempt this.
Old Oct 28, 2007 | 09:01 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Well, judging by the other topic I assume your talking about doing a T-56 swap with electronic guages. It's simple enough, although fairly costly if you're keeping your ECM.
Assuming you want to keep your ECM and/or cruise control, you will need to pick up a Dakota Digital SGI box (should be SGI-c or something) and wire it it up. You then need to find and cut the two brown wires coming out of the guage cluster connectors. One goes to the cruise control module, and the other to the ECM. You will need to split the VSS signal, and run one to the speedo, and the other too the DD box. You will then need to run the buffered output into those two wires.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
