gta deluxe door panels
Old Oct 30, 2007 | 06:36 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
i just got a set finally off of ebay and i was hoping to take out the carpet insert and refinsh it but this seems to be harder than i thought anyone have an idea?
Old Oct 30, 2007 | 07:54 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: gta deluxe door panels
Need help removing the carpet? Removing the door panels? Reinstalling carpet / door panels? What exactly do you need help with?
Old Oct 31, 2007 | 03:02 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
need help with removing the carpet with out wrecking the door panel im thinking heat gun!
Old Oct 31, 2007 | 03:26 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
Signed on
Old Nov 2, 2007 | 07:18 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
nobody???
Old Nov 2, 2007 | 02:20 PM
The carpet thats ON the door panel, or on the floor? I cant see anyone wrecking a door panel removing the carpet off the floor, I am not sure how to remove the fabric off of the door panel. It IS cardboard like material and is relatively fragile. You can buy Blank door panels from Paddock, if thats the case, Good Luck.
Old Nov 2, 2007 | 02:36 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I don't see door panels for any year at the Paddock.
I would take a utility knife and carefully cut around the carpet, then peel it off possibly use a little heat and then figure out something to replace it and make it look good. But be careful, like said they are pretty fragile.
I plan on recovering mine in a fake leather or a nice fabric eventually. Maybe make a mold of the panel its self and make some fiberglass ones.... but that is a long way away. I have 2 pairs to use/try on
Old Nov 2, 2007 | 10:53 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
IIRC, Jim85IROC restored a set of "GTA" panels and posted some pix. You might try doing a search for it or sending him a PM about it.
Old Nov 8, 2007 | 11:58 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Since the fabric section is actually under the vinyl section and attached to it, you pretty much have to cut it out or install a new section on top of it. I built a new insert and put it above the original, but it didn't come out as great as I had hoped. Here are some pictures.
assembling the new insert:
the door panel after dying black (was gray)
new insert installed
what I don't like is how the impressions show from where the pins are pushed through holes I drilled in the door panel. If I were to do it over, I would cut out the insert and adhere it to the bare panel. I will probably do just that in a year or so. The material I used is headliner material. It matches what I used on the headliner and to cover the rear speakers in the sail panels.
Old Nov 8, 2007 | 12:58 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I am guessing you did not use any padding under the panel on top of the pins or what ever you used? I think if you put a thin pad underneath it would look better afterwards, just a suggestion
Old Nov 8, 2007 | 04:59 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
The pins are actually adhered to the back side of the board. When I tried to put the pin through the board, the headliner material wasn't plush enough to mask the bump. The headliner material has an 1/8" foam backing, but that doesn't hide much. The real problem that I didn't anticipate is that the backing board I used was too flimsy and was "sucked in" by the pins causing the divits to appear.
Old Nov 10, 2007 | 07:34 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
wow jeremynyr thats still impressive i like it
Old Nov 15, 2007 | 04:44 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
subscribe mearly cause i have practice panels and you just gave me some inspiration!!! thanx
Old Nov 16, 2007 | 01:54 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
What you NEED to do is make some new panels, cover them in 1/4 inch CLOSED CELL FOAM and cover THAT with a fabric like the headliner/sail panel material. Closed cell foam is soft but dense (I could make a political joke but I shall refrain...) and is easy to work with. Just make sure you scuff it with some sand paper so that the glue will adhere and use the
3M heavy duty contact cement.
Old Nov 20, 2007 | 04:58 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
thank you :-) I'll be sure to post when I eventually improve them
Old Nov 20, 2007 | 05:09 PM
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
Nice job mate, I may have to steal your idea for my GTA
Old Nov 21, 2007 | 11:12 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
you can use 1/4 plywood for the insert and wrap it with a quality vinyl or i used synthetic ostrich. use a spray adhesive for the vinyl and construction adhesive for the plywood. clamp the plywood to the panel after its wrapped and let it set for a few hours. I have a few pics of the panel i just finished up under ws6 door panel
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
kkirch15
Interior Parts Wanted
Aug 28, 2015 10:03 AM
Out-Cast
Aug 23, 2015 06:33 AM
