strange power lock problem...
Old Nov 29, 2007 | 03:20 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I went to start my car today and the batterys dead, since I dont drive it very much I dont think anything of it, I go to jump it, but then I hear my door locks going on and off. every 5-10 seconds both my door locks lock then unlock. then since I had my door panels off already I disconnected the lock motors. please tell me theres a simple (cheap) way to fix this.
edit: I also know I recently had a mouse in my car. so any wires I could check to see if they're eaten threw?
Old Nov 30, 2007 | 06:28 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: strange power lock problem...
nobodys had anything like this? if someone could just tell me some wires to check or anything that'd be great.
Old Nov 30, 2007 | 07:18 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
The only thing I can think of that would cause that to happen is a wire shorting out. Sounds like its shorting to a piece of metal and not another wire. Since your door locks went crazy, I would check the wiring going to the lock actuators and trace their path all the way back into the car. The wires tend to wear out inside of the rubber boot that they run into the door through since it moves and rubs up against them a lot. That would be the first thing I would check. Hope this helps out
Old Nov 30, 2007 | 07:25 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
thanks, only reason I havent checked that yet is that it happened to both doors at the same time. guess Ill check it anyway tomorrow.
Old Nov 30, 2007 | 08:47 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Well, because the wires for both actuators are on the same harness and run through the same relay, a short could cause them both to have problems
Old Nov 30, 2007 | 09:00 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
awesome, hopefully it'll be something simple, thanks.
Old Nov 30, 2007 | 11:36 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
You might want to read this thread. It dose have the power door lock wiring diagram in it, along with pictures and locations of some of the components.
http://www.p71interceptor.com/thirdgen/powerlocks/
Dave
Old Dec 1, 2007 | 12:43 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Dave
thanks, Im sure that'll help.
Old Dec 1, 2007 | 10:55 PM
90 GTA Black's Avatar
This happened to me a couple months ago. It turned out to be the positive battery terminal that wasn't tightened correctly and had corroded slightly. It allowed just enough power to jump the locks and flick some of the gauges on the dash. I fixed it by charging the battery and cleaning the terminal.
Old Dec 1, 2007 | 11:37 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
I had the "lock" button on the drivers side, of course, stick "in" in the "on" position and cause a constant short that would drain the battery in a few days. Worth a check brother.
Old Dec 2, 2007 | 12:24 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I think those both sound like they could be the reason too because my passenger side lock button has stuck on me before, and since Ive been doing alot of work on the car lately Ive been disconnecting the battery alot. Ill check both these too. thanks
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
