What seat belt to use...
Old Nov 29, 2007 | 11:20 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I want to get either a 4 point or a 3 point harness for autocrossing next season. I was wondering what would be easier to use in my car (It doesn't have a roll bar or anything). I was thinking I would get a clip in 3 point and clip the lap belt to the two floor spots by the drivers seat and the third clip would go to the back seat retractor mechanism. Then the shoulder straps will go over the back of the seat and under the headrest. Will that work? The site mentions eyelets... would an eyelet work?
Link to what I was looking at:
http://www.corbeau.com/products/2_in...s/2_inch.shtml
Old Dec 2, 2007 | 05:49 PM
russ89gta's Avatar
Car: 1989 pontiac trans am gta
Engine: tpi 5.7
Transmission: th700r4
Re: What seat belt to use...
I put a pair of those in my car, they will bolt in to the factory seatbelt holes. I ran them up under the headrest. I haven't used them at the autocross yet, but they held me tight in my seat when I went to road atlanta back in may.
Russ
Old Dec 3, 2007 | 12:34 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
have any pics of the install? they will work with stock seats? which belt/ options did you go with? do you guys think the retractor option is a good idea for a daily driver?
Old Dec 3, 2007 | 11:35 AM
Car: 1987 IROC-Z
Transmission: TH350
I would alos like pics and know what belt/options you have with it. However, using one of these harnesses for daily driver is illegal. These harnesses may be safer but they are not legal DOT seatbelts. If you are using a race harness while your on the road and you get pulled over and the cop sees it... time for a ticket. Thats why I just want something that will be easy in easy out for when I autocross.
Old Dec 3, 2007 | 01:09 PM
Stephen's Avatar
Car: 87 GTA
For the shoulder belts, I've seen a bar mounted for rear tower to tower, to act as the mount for them. Pretty cool idea. Mounted right at the height of the rear seat, and they are practically invisible, from the front.
Make sense?
Old Dec 3, 2007 | 01:30 PM
Car: 1987 IROC-Z
Transmission: TH350
I think I know what you mean but would I have to take out the rear plastic peices, or would it just mount where the cargo shade does? If it would mount where the cargo shade does, would it be strong enough?
Old Dec 3, 2007 | 01:32 PM
Stephen's Avatar
Car: 87 GTA
I've seen them before, but can't pics right now. I'll keep looking.
Old Dec 3, 2007 | 01:39 PM
Car: 1987 IROC-Z
Transmission: TH350
Old Dec 3, 2007 | 02:00 PM
Stephen's Avatar
Car: 87 GTA
No luck yet, but I found this that'll help illustrate mounting options. Even using the stock rear seat belts mounting points could be a good choice.
Old Dec 3, 2007 | 02:26 PM
Stephen's Avatar
Car: 87 GTA
Here's a text version of a Forum Thread, that talks about what I mean....
thread
But if you mount the 2 ends of the bar, to where the rear shoulder belts mount, your basically just as safe, as far as the mounting goes, since your using strengthened factory mounting points.
Old Dec 3, 2007 | 03:12 PM
Car: 1987 IROC-Z
Transmission: TH350
My car doesn't have rear shoulder belts... just lap belts, so I have no idea what you talking about.
The blue circle is what I was planning on doing in my car. With the bar going across over the rear wheel wells are you reffering to the picture circled in red?
Old Dec 3, 2007 | 03:31 PM
Stephen's Avatar
Car: 87 GTA
Well, I couldn't find a real pic, so I made one to illustrate it. Red is the bar & tabs, blue are the belts. With earlier models, mounting to the sheet metal, and using mounting plates like a roll cage uses or back plates, would provide strength too.
Obviously for a 4 point, you'd use 2 mount tabs per side.
Old Dec 3, 2007 | 04:04 PM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
theres another thread with more pictures in it..but it was pretty much declared unsafe to mount them this way
https://www.thirdgen.org/forums/inte...ount-5-pt.html
Old Dec 3, 2007 | 04:15 PM
Stephen's Avatar
Car: 87 GTA
That red Camaro is EXACTLY what I was referring too.
As far as "track legal", no. It's not going to meet safety standards. But for local autocrosses, then yeah. It PROBABLY will, unless you have some real hard-***.
That's what I plan on building. I don't have rear shoulder belts either, so it would require some extra fab work, since there aren't any shoulder belt mounts.
Old Dec 3, 2007 | 06:09 PM
Car: 1987 IROC-Z
Transmission: TH350
A complete roll cage is legal in the stock class for autocross. I just dont want to give up the use of my back seats, and I like the stock look.
Old Feb 13, 2008 | 11:50 PM
rubyrottenapple's Avatar
http://www.carolinaclicks.org
Old Feb 14, 2008 | 03:40 PM
Car: 1987 IROC-Z
Transmission: TH350
the above link is spam.
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
MORREALE5
Sep 13, 2015 09:01 PM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
