removing a 89 IROC shift knob
Old Dec 9, 2007 | 04:04 PM
camaro55427's Avatar
Car: 89 Iroc z
Engine: 350 carbed
Transmission: built 700 R4 2200 stall
Axle/Gears: 3.73 10 bolt
removing a 89 IROC shift ****
has anyone takin a Irocs shift **** off the auto shifter without breakin it? and if so please leave details how and wat to watch out for
Old Dec 9, 2007 | 04:27 PM
Car: 89 Iroc z
Engine: 350 carbed
Re: removing a 89 IROC shift ****
scratch that, i got the button off and the spring but the rest wont budge, i didnt want to fu anything up so i didnt pull as hard as i could
Old Dec 9, 2007 | 05:22 PM
Steve86TA's Avatar
Car: To many to list
Slow down and take a deep breath..................Now put the shfter back in a low gear and you will see a small slit in the front.There is a U clip that holds it there.Use a small flathead screwdriver and pry it out.Takes 2 seconds
Old Dec 9, 2007 | 05:41 PM
Car: 89 Iroc z
Engine: 350 carbed
ya i did it ha, i just in from doin it, i didnt look at it well at first, i got it off, thx
Old Nov 19, 2015 | 06:14 AM
87zeder's Avatar
trying to get mine off as well got the button off and the spring, but I don't see any clip in the front of the **** where it's suppose to be... still no luck coming off!!!
Old Nov 19, 2015 | 09:05 AM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Looks like a horizontal slot at the base of the ****. Just a "U" shaped wire keeper
Old Nov 20, 2015 | 10:11 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
the shift ***** on the autos are press fit, after removing the button, spring and retainer from the top of the ****, they have what looks like a heavy duty staple on the front(side facing front of car), if the staple has already been removed(and probably lost long ago) you will just have two dots on the handle where the staple would go
other than that you just wiggle and yank on it really hard until it pops off
Old Nov 20, 2015 | 08:33 PM
87zeder's Avatar
Yeah just looks like to small holes where the staple would go.. i've pushed screwdrivers in thinking maybe it's broke off inside the holes???
Old Nov 21, 2015 | 11:57 AM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
If you don't see the staple in the front of the shifter take the button off and make sure there isn't a snap ring inside. For some odd reason I remember one of my projects having one there.
Old Nov 21, 2015 | 11:59 AM
87zeder's Avatar
Hmm never saw one inside
Old Nov 24, 2015 | 02:39 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Harrison5 is correct..............
It MAY be the held in place with the snap rings depending on the years
or if they ran out of/changed something while on the assembly line.
I have seen both.
Old Nov 24, 2015 | 03:37 PM
jharrison5's Avatar
Car: '87 IROC
Im glad someone else knows what I'm talking about because I thought I might be going nuts...
Old Dec 21, 2015 | 10:56 AM
Young-IROC-Z's Avatar
Car: 1989 IROC-Z Z-28
Engine: 5.0 liter 305 small block V8 TPI
Transmission: Manual
Axle/Gears: 5 speed
Does anyone know how to remove the shift **** on an '89 IROC manual transmission?
Kind of a stupid question, my apologies. I am very new to cars(I'm only 14).
Old Dec 21, 2015 | 11:00 AM
jharrison5's Avatar
Car: '87 IROC
Righty tighty lefty loosie lol! It just screws off like a nut.
Old Jan 5, 2016 | 07:06 PM
Axle/Gears: 5 speed
Thank you, your help is much appreciated.
1992 Trans Am
May 10, 2023 07:19 PM
dhonda200
Aug 11, 2015 11:50 PM
mustangman65_79
Aug 11, 2015 03:17 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
