Light? under dash behind vents (1991)
Old Dec 11, 2007 | 11:12 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Is that a yellow light that is located behind the vents under the dash pad? I have my interior stripped right now as I fix previous owners wiring splices, etc and I can accross it. It is a 1" square peice inset to the underside of the dash and has what looks like a yellow light in it. It has 2 wires going to it in a factory harness. Can't locate it in my GM service manual. What is it? What does it do?
Old Dec 11, 2007 | 11:44 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Light? under dash behind vents (1991)
possibly one of the lights for the HVAC control or counsel, if it is small that is.
Old Dec 11, 2007 | 11:49 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I've also seen that called an ash try light, since that is the area where it projects.
Old Dec 11, 2007 | 11:50 PM
Dennis-Z28's Avatar
That is it pulled out.
Old Dec 12, 2007 | 12:00 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
its a light but on most they dont give off any good anount of light. they have em there cuz its not a well lit aera on the camaro . just put an led in there
Old Dec 12, 2007 | 12:09 AM
CanadianRoots's Avatar
Car: 91 Camaro RS
Engine: 305 TBI *355 Coming Soon*
Transmission: 700R4 *T56 Coming Soon*
Axle/Gears: 323
I recently put a blue LED in it and put it on a separate switch with some LED's I mounted in the heater vents...
Old Dec 12, 2007 | 03:00 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Theres more mystery and drama around that bizarre light than anything else on these cars!
All we have is speculation about what it's for. COncensus seems to be that it lights up the HVAC/radio area.... but it doesn't do a very good job of it.
Old Dec 12, 2007 | 07:28 PM
Dennis-Z28's Avatar
I sure found it mysterious. Guess it comes on with the dash lights then? Hmm, will have to keep an eye on it when I get these wires all sorted out.
Old Dec 13, 2007 | 04:25 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
It's meant to illuminate the console at night. It's meant to be only bright enough to help your eyes easily find the locations of the ashtray and shifter, etc, without being to bright to be irritating at night.
That's correct, it does come on with the gauge/dash. It's a gentle light, but if you think it should be brighter, check to see if it even works. If it does, the bulb hole may be filled with dust/dirt.
Old Dec 13, 2007 | 06:12 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
'89 was the first year for that light.
Old Dec 13, 2007 | 06:28 PM
Axle/Gears: 3.08
Cool!
That I did not know.
Old Dec 13, 2007 | 08:54 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
pre 89 had a different sytle then cuz i have an 87 and i have a different stlye one
Old Dec 14, 2007 | 05:56 PM
Engine: that I like
It must have been added because the only pre-'89 I've had with a light there was an '86 Z28- and it had the dash from an '89 put in it.
Old Dec 14, 2007 | 06:30 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
my 87 has this light too...
Old Dec 14, 2007 | 08:21 PM
Axle/Gears: 3.08
It appears as though what models and years, exactly, had this light is still up in the air.
Old Dec 15, 2007 | 01:48 AM
Guy In A 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
I need to get one of those. . .lol mine is missing. I feel like I'm missing out. I only noticed it after I bought my car. While cleaning it I felt a big azz hole under the dash and wondered what it was for. . .
Old Dec 15, 2007 | 09:48 PM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
My 85 doesnt have it and my friends 88 does not have it.
Old Dec 16, 2007 | 10:49 AM
Stephen's Avatar
Car: 87 GTA
My 87 GTA and the 89 GTA I stripped for parts, both have the same kind. About 2" long, 1" wide, and rounded ends.
Old May 29, 2017 | 10:20 PM
David91Z28's Avatar
Car: 1991 Z28
Engine: LB9
Transmission: WCT5
What led did you replace it with?
Old Jun 5, 2017 | 03:41 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
the light itself has a yellow plastic up front. I took one from another car that I put in a white led and I am going to be putting it inside my center console.
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Pilotrick50
Sep 2, 2015 12:48 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
