Hatch Pull Down Latch Mounting
Old Dec 21, 2007 | 10:34 PM
Procat's Avatar
Car: 88 Camaro IROC
Transmission: THM 700R4
Hi,
So just bought a black 88' Camaro Iroc and the pull down latch was not mounted. I have taken off the plastic panel in the back and I don't see any mounting holes and the pull down unit doesn't seem to fit well. Is there a mount or something I need?
Pics of an installed one would probably be helpful if someone has them.
Cheers,
Isaac
Old Jan 12, 2008 | 12:24 AM
Procat's Avatar
Car: 88 Camaro IROC
Re: Hatch Pull Down Latch Mounting
A pic like this with the pull down mount would be helpful. I don't see any mounting holes?
Old Jan 12, 2008 | 12:39 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
yea you've been robbed of the mounting bracket...your going to need to go to a junk yard with tools and a power drill and drill out the spot welds of a bracket and re-weld it to your car...as far as measurements i can try and help you out but it's not going to be fun...here are the pics you asked for...this is from a bird...but they may be identical bird to maro...but either way you will get the idea.
Attached Thumbnails Hatch Pull Down Latch Mounting-rear-pull-down-motor   Hatch Pull Down Latch Mounting-rear-pull-down-motor   Hatch Pull Down Latch Mounting-rear-pull-down-motor
Old Jan 12, 2008 | 02:41 AM
Procat's Avatar
Car: 88 Camaro IROC
Thanks for the reply and the pics... =\
Not really what I wanted to see. =)
Old Jan 12, 2008 | 07:59 AM
ezliving4ume's Avatar
Car: Forrest 91 t/a
Engine: 5.0 tpi w/underdrive/accel,full 3"
Axle/Gears: 3.73 pos
U MITE WANT TO CHECK YOUR MOTORIZED LATCH ASSEMBLY TO MAKE SURE IT WILL WORK.
It looks like a good time to throw out the motorize latch and get a standard latch. The motorize one has all kinds of issues.
Old Jan 12, 2008 | 11:01 PM
jamesnelson101's Avatar
i totally agree with ezliving....if you are starting with nothing go with the regular hatch, you will definately save yourself alot of agony
Old Jan 13, 2008 | 06:40 AM
Kjohn21365's Avatar
Car: '88 Formula Firebird
Amen Brother! I have replaced the motorized one twice and have rebuilt the 2nd once thanks to Top Down Solutions for the great rebuild parts. But do not use the motorized latch if you can help it - even rebuilt it SUX.
Old Jan 14, 2008 | 07:57 AM
Car: Forrest 91 t/a
I've went thru three of the motorize latches in the last two and a half years. I don't even drive the car that much!
The first one was just old, the plastic guides wore out & cracked the gear housing. The second one, Ice built up under the trunck lid. Then when the latch came down it striped the gears. The third one is a rebuild from parts of #1 & #2 but, it works!
I guess I've installed three but only two have went bad
Vintageracer
Jan 10, 2020 05:33 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
madsv1000
Aug 20, 2015 06:45 AM
Randomtask2
Aug 13, 2015 01:57 AM
z28addict8490
Aug 7, 2015 08:48 PM
