Dash Replacement
Old Jan 29, 2008 | 12:00 AM
Dirk Edgewoode's Avatar
Dash Replacement
Can anyone point me in the direction for some instructions for removing and replacing a dashboard? Looked through the technical articles to no avail. Anyways, how serious of an undertaking is this? Looking at a descent Third Gen with a badly cracked dash. Never done any kind of interior work what so ever, a real neophyte. Would I be better off finding a car with a good dash? lol
Not looking to swap any instruments, just the dash pad.
Old Jan 29, 2008 | 12:05 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: Dash Replacement
4 screws on top front middle under the windshield. then I beleive 8 on the underside then take it out, easy as that
Old Jan 29, 2008 | 12:26 AM
On the underside? Do you mean where the gauges are?
Old Jan 29, 2008 | 09:14 PM
Racer350's Avatar
Car: 1988 IROC-Z
Axle/Gears: 3.45
the screws are directly underneath the dash pad itself, all along the outside perimeter of the pad. not just by the gauges
Old Jan 29, 2008 | 09:51 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
the dash pad is very very easy to take off once our goin to take it off it explains its self
Old Jan 29, 2008 | 10:20 PM
fignewton's Avatar
Car: 1984 Z28
Engine: .030 over 350 4 bolt .480/292 cam
Transmission: Tremec TKO 600
Axle/Gears: 3.27:1 posi
Do the contortionist thing and lay your back onto the seat bottom and look at the underside of the lip of the dash and you will see the screws.
Old Feb 2, 2008 | 10:51 AM
dj82z28's Avatar
Car: 82 Z28
Engine: 305, some mods
Transmission: 280 metric
Axle/Gears: 3.23 Limited Slip
dont forget about the 4 in the defrost grille
Old Feb 29, 2008 | 08:55 PM
Boaisy's Avatar
Car: 1987 IROC-Z Camaro
Engine: LB9 305ci V8 TPI
Well since this is the closest post to my question, if you happen to accidentally drop a screw (one of the 4 in the front) and it falls into the defrost vents, how would one go about obtaining the screw? I tried fishing it out with a magnet on a string, but I could not find it. Taking out the dash to get to the vents is an option, but then I would need to know how to get the dash off to access the vents. My car is a 1987 IROC-Z. I have a whole week of spring break to do whatever, and I have already taken the speedometer out because we have to get it fixed. Any help would be greatly appreciated.
Thanks in advance,
Boaisy
Old Feb 29, 2008 | 10:19 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Thanks in advance,
Boaisy
when i dropped one, in about a week it found it's way down(i don't think it fell exactly into the vent), so you could drive for a week and might get lucky
Old Mar 1, 2008 | 10:27 AM
Boaisy's Avatar
I wish I was that lucky in this case.
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
z28_AJ
Aug 27, 2015 08:59 PM
justin57
Aug 20, 2015 07:05 PM
marcusaw
Aug 10, 2015 08:13 AM
