Passenger and Driver Seats!!
Old Jan 30, 2008 | 06:13 PM
TPI-RS's Avatar
Car: 1991 RS Hardtop
Axle/Gears: 3:23
As we all know, the drivers seat clearly takes more abuse. Here is my question. Is it possible to take the bottom foam and fabric off the passenger side and replace it on the drivers side? I know all the reclining mechanisms would have to be moved? but has this been done? pictures/advice? anything! Thanks guys!
Old Jan 30, 2008 | 06:23 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Passenger and Driver Seats!!
I know the seat skin (fabric) is the same part if you order them, the foam im not sure of but i do believe it is.
Old Jan 30, 2008 | 06:25 PM
TPI-RS's Avatar
Axle/Gears: 3:23
do you know how i can find out? what about the upper section of the seat? same fabric as well?
Old Jan 31, 2008 | 03:37 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Yes you can interchange it. My drivers seat was heavely worn and I found a passenger side that was perfect, took it to an upholstery shop, and they changed out the basket and the foam and the fabric and I had a perfect drivers seat.
Old Jan 31, 2008 | 03:19 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
so then either way its not a matter of swapping an entire passenger side lower to a driver side upper
Old Jan 31, 2008 | 03:46 PM
Pocket's Avatar
Car: 91 Trans Am
I swapped cloth covers
The top is held on by a zipper at the bottom and a few hooks if I remember right
Sew up the 1/2" slit from the tilt and make another 1/2" slit on the other side
Its really simple
Old Jan 31, 2008 | 07:23 PM
TPI-RS's Avatar
Axle/Gears: 3:23
thanks for the response... mcgarnicle when you say the basket what exactally are you talking about?
Old Feb 1, 2008 | 09:47 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
It's the little wirey springy peice, you'll see it at the bottom of the seat.
Old Feb 1, 2008 | 05:28 PM
TPI-RS's Avatar
Axle/Gears: 3:23
very technical terms! ha. I'll have to check it out...
Old Feb 1, 2008 | 06:00 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
None of the mechanical pieces that make it slide or recline need to be moved.
I assume the "basket" of the seat would be where your bottom would be while sitting in the car.
Food for thought:
Cut the back out of the foam pads in the seats while they're uncovered and insert a set of the portable heated/massage seats you can find at most wal-marts for about $25. Most already run on 12+ DC. Just the heat alone is worth it IMO.
Old Feb 1, 2008 | 06:16 PM
TPI-RS's Avatar
Axle/Gears: 3:23
hmm, yeah, the car has never and will never see salt tho, so there is no need to have a heated seat! thanks tho.
so... will the tracks on the drivers seat bolt directly onto the bottom of the passanger seat bottom? if so, i assume i dont even need to get the covers swapped, i can just swap the bottoms correct?
Old Feb 2, 2008 | 10:34 AM
dj82z28's Avatar
Car: 82 Z28
Engine: 305, some mods
Transmission: 280 metric
Axle/Gears: 3.23 Limited Slip
if all you are trying to do is repair a ripped seat cover/ worn out foam. there is really no need to even remove the seat from the vehicle. there are little j clips that hold the seat cover on a flat head screwdriver and you got the cover off, for the bottom.
like they said the back is zippered.
plus heated seats are just cool and they are worth it when it gets cold.
Old Feb 2, 2008 | 11:14 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
[quote=TPI-RS;3622320
so... will the tracks on the drivers seat bolt directly onto the bottom of the passanger seat bottom? if so, i assume i dont even need to get the covers swapped, i can just swap the bottoms correct?[/quote]
Not exactly, the controls will be on the wrong side then. The way the shop that I went to did it was they took the fabric off and then where the holes for the controls are they replaced it with the side from the original drivers seat fabric.
hope this makes sense.
1992 Trans Am
May 10, 2023 07:19 PM
LittleFranks
Sep 17, 2015 12:22 PM
zayne0
Aug 24, 2015 07:22 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
