rear window defroster
Old 02-07-2008, 04:36 PM
J_Dubb44's Avatar
Car: 1984 Pontiac Trans Am
The rear defroster on my 84 TA doesnt work. When i press the button the light comes on and the wires are connected to the rear hatch shocks like they are supposed to be. Any idea why its not working?
Old 02-07-2008, 05:13 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: rear window defroster
get a digital volt meter (best alternative) or a 12V lightbulb from like radio shack or something and test the lead coming out of the driver side that first connect to the shock...check for 12V there after you put the gounding lead on the body...if you get voltage...proceed to the end of the shock and do it again...then proceed to the other end of the hatch same side of the shock, do it again...then go to the bottom terminal and check it again. Somewhere in there you will get a break...if it's not getting power at the beginning right behind the rear driver side seat...then it's a wire prob between there and the switch...if it's at the end of that shock somehow the shock is bad...if it's in the third location (passenger side shock closest to the spoiler) then it's somewhere in the window. if it breaks when you get to the bottom (towards the rear passenger seat) with no voltage then the passenger side shock is the problem, and from there if you get voltage down there...then there is a problem with the ground wire right there underneath the plastics. From experience i've never had problems with the shocks so i figure it's betwee then switch and shock, in the window, or the ground between body and passenger side shock. That should be a complete insight on the curcuit so if it comes back and it's between the switch and the bottom of the driver side shock then we can check a couple other things.
Old 02-09-2008, 06:08 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
Only a few lines on my defroster work....is there a way to make them all work?
1992 Trans Am
05-10-2023 07:19 PM
Vintageracer
01-10-2020 05:33 PM
69 Six Pack
10-05-2015 07:51 PM
AkDrifted
08-17-2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
08-08-2015 11:48 AM
Quick Reply: rear window defroster
