A-pillar
Old Feb 8, 2008 | 06:27 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
A-pillar
So today was a nice day in florida and i decided to take the tops off and drive around. WHile driving i noticed that i seem to have a gap in my plastic a-pillar piece. Almost like its not screwed down the whole way. I took the one screw off near where the t-tops would fit in and it seems that this plastic a-pillar is glued on? Is this this case? My passenger side doesnt have this gap, the a-pillar fits sung up on there but i can stick my fingers in the gap on the driver side. I Dont want to go pulling it apart without knowing how its held on there so can anyone tell me how its on there? Car is a 91 RS Camaro with t-tops.
Old Feb 8, 2008 | 08:27 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: A-pillar
There are 2 "clips" (similar to the clips that attach the door panels),that snap the a pillar plastic. Just be real careful, the plastic trim gets brittle and will brake easily. I ended up gluing one of the clips in place on the plastic, and then re-installing it.
Old May 4, 2008 | 01:35 AM
Crouchman's Avatar
Car: 1988 Iroc convertible
Engine: 305TPI
Transmission: T-5, swapped it in.
Axle/Gears: no clue, but I'll learn
Re: A-pillar
are these clips available, or can you modify a door clip? Same problem, getting ready to put the trim back on, see the slots. Plus my weatherstripping is awful...dried out-cracked/brittle. Chased the weatherstrip dog before. Nothing out there, except to order custom.
Old May 5, 2008 | 09:26 PM
krisb410's Avatar
Re: A-pillar
Dealer has em
Old May 6, 2008 | 11:27 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: A-pillar
you can also get them at auto zone/ advanced for a good amount cheaper
Old May 7, 2008 | 07:57 PM
Crouchman's Avatar
Engine: 305TPI
Re: A-pillar
thanks Kris! On the list of stuff I need.
thanks wheels...I can get there more conveniently than the dealer, although I do need to go there, too. Few odds & ends, plus the IROC decals for the doors. Bolts for the plenum extension/distributor cover, bolts for the door handle.
aharvel50
Sep 21, 2015 07:31 PM
WECoyote
Aftermarket Product Review
35
Apr 21, 2002 09:41 PM
RMK
Nov 19, 2000 08:17 PM
JEFJM
Oct 16, 2000 08:49 PM
