Covan Classic
Old Feb 11, 2008 | 07:34 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Covan Classic
I have bought the Autometer guages to go in the blank Covan Classic cluster. My plan is to run mechanical gauges except for the volts.
How will I be able to hook up the turn signal and the high beams? I bought all my pieces separate instead of the plug and play kit. I wanted mechanical over the electrical.
David
Old Feb 12, 2008 | 03:25 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Covan Classic
When you take the old cluster out and you cut out the old plugs you'll have to just go through with a test light and figure out what everything does. The turn signal wires are blue and you would just need to wire a light into them, or if you're using LED's you'll need a resistor I believe. Pretty much the same for the high beams test light the open wires with the headlights on with the high beam and figure out which wire it is and run a light source through it.
dmccain
South East Region
Sep 30, 2016 06:23 AM
z28venezuela
Oct 24, 2015 08:15 PM
3.8TransAM
Oct 1, 2015 07:47 PM
75bike
Sep 20, 2015 09:37 PM
84 TA NV
Sep 6, 2015 08:02 PM
