Sun Visors
Old Feb 12, 2008 | 02:29 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Sun Visors
I bought a new headliner and sunvisors from hawksthirdgenparts.com. But the sunvisors wont stay up no matter what i do. Has anyone had this problem?
Old Feb 12, 2008 | 03:09 PM
Oscar's Avatar
Re: Sun Visors
yeap, probably the sleeves are worn out. I just bougt a set and now they they stay up. see the link.
http://www.top-downsolutions.com/pro...310f784287996c
Old Feb 12, 2008 | 03:57 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Re: Sun Visors
the visors are brand new so the sleeve shouldnt be bad, I think its the pin that goes inside, because mine spin around in the base.
Old Feb 12, 2008 | 04:51 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Sun Visors
it's not the visor , its not the sleeve . remove visors from brackets and i am sure that you will find that the silver shaft is turning in the arm housing . i did a temp. fix on mine . remove brackets from car (good time to clean and lube pivot area ) . clean silver shaft/housing area . i used carb. cleaner with plastic straw . clean good , rotate shaft more carb. cleaner , rinse area alcohol . let dry . place in vise or clamp with silver shaft upright . a few drops of locktite on base of shaft , rotate shaft , make sure all air is out shaft housing another drop of locktite . let set 24 hrs. re-install . worked for me .
Old Feb 12, 2008 | 05:12 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Sun Visors
Common problem in our cars:
https://www.thirdgen.org/forums/inte...un-visors.html
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
PurelyPMD
May 5, 2016 04:57 PM
1MeanZ
Dec 18, 2015 05:39 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
andy74
Sep 3, 2015 08:41 AM
