Steering column trim removal??
Old Feb 28, 2008 | 11:15 AM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
Does anyone know if the plastic trim that goes around the stering column at and just behind the turn signal switch can be removed without piulling the steering wheel?
All I'm trying to do is get to the linkage between the turn signal lever and the bright dim switch.
Whn I pulled the turn signal lever towards me to switch to brights it felt like something broke. Now it is stuck on bright. I pulled trim and brackets to lower the column, and found the bright/dim switch. It is activated by an arm that depresses it when the lever is pulled towards the driver. I tested the switch by pushing on it and it still works, so the prolblem is that the lever/arm is not pushing the switch all the way.
Not sure exactly how I will fix this but it doesn't sound too complicated. I just have to get to it...If anyone knows how to fix this problem suggestions would help. Mainly I just need to get that trim off to see the problem, though.
Old Mar 18, 2008 | 03:34 PM
lonesomecrow's Avatar
Car: 92 RS
Engine: 305 TBI
Axle/Gears: ??
Re: Steering column trim removal??
yes I would like some help on this too pls!
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Oenone
Aug 29, 2015 07:54 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
