Seat belt Re-call
Old Mar 3, 2008 | 01:50 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Seat belt Re-call
i know this is one of the talked about issues on here, but i was wondering if anyone has had any luck getting the re-call done, here lately. If so what kind of act of congress did they have to go through to ge the a-holes at the dealership to fix it. All i get is the run around, and to me it would seem like a liability issue if i got hurt in a wreck due to it failing and the dealership not honnering the recall
BTW refresh me on the years it covered and what the recall # was, i had all this info and seemed to have lost it
Old Mar 3, 2008 | 02:47 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Seat belt Re-call
It is a little late on that recall, if I remember it was in 1988 and it was for the unlock push button and NOT the seatbelts. Also I don't think the Dealers too worried about liability issue on a 20+ year old recall. So sue the previous owners for not having it done.
Old Mar 3, 2008 | 03:06 PM
89RS_82Z's Avatar
yea the push button, that basicly shatters the locking mech when you apply any force to it like a wreck, GM says i should be able to get it done at any dealership, but none want to do it
Old Mar 3, 2008 | 03:22 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
It's a recall on a system that is prone to life-endangering failure. Those recalls are for life. The original text of the recall was to have customers come in and have the buckles looked at. If they looked fine, they were marked off the list. This is why I think so many of our cars aren't in GM's VIN recall database. Because this recall changed over time from inspect, then repair, to flat-out replace.
Old Mar 3, 2008 | 04:36 PM
89RS_82Z's Avatar
yea as far as i knew once the NHTSA issued a recall, it was effective for life and had to be done if your car qualified, mine does.....
anyone know the recall #??
i wish someone had luck getting it done, i really dont want to do it my self, rather leave seatbelts to a dealer to do
Old Mar 3, 2008 | 05:02 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
can't comment on the seatbelt recall but I can tell you that recently I did recall on a mid 80's olds for a evap vent solenoid.. the car had about 200k on the clock and barley ran but they still honored the recall. The customer wasn't interested in anything else..
Old Mar 3, 2008 | 05:35 PM
89RS_82Z's Avatar
well my friend DJ82Z28 works at a chevy dealership, i going to see if i give hime my keys for a day, if he cant pull some strings
was it recall #90043
p/n 14097930
Old Mar 8, 2008 | 05:52 PM
tekkitan's Avatar
Car: 87 IROC-Z
there is also a nice long sticky post at the top of this forum about the recall.
Old Mar 9, 2008 | 04:27 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
I had mine done 8 years ago, but here's my receipt. At least it's solid proof of a dealership doing it (albeit Canadian) and the campain (recall) # is listed (looks like you're correct on those).
Good luck. As mentioned this is a life saving device and the dealership should honour it. Replacing the seat belt buttons does require a specific tool that many dealerships do not have, they may be to lazy to bother but that's no excuse.
Old Mar 10, 2008 | 06:21 PM
89RS_82Z's Avatar
yea i needs to be done, i will keep yall posted if i get any luck
Old Mar 10, 2008 | 06:57 PM
my82roc's Avatar
Car: 89 Iroc Convertible
I replaced the seatbelt buckle push buttons myself.The kits are still available and you just need a flat bladed screwdriver to do it.I see on your invoice that you have recall# 90007 for the top latches.What was the problem as i just found out about this today for my 89 vert
Old Mar 10, 2008 | 06:59 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
You can always do it yourself. I purchased a NOS seatbelt button kit on EBAY for $6.50 Took about 45 minutes to install. I did a search on EBAY under "Camaro NOS" The guy has a bunch of sets left.
Old Mar 10, 2008 | 09:54 PM
Axle/Gears: 3.08
Check out . . . https://www.thirdgen.org/forums/conv...ml#post3673031
Old Mar 12, 2008 | 02:20 PM
89RS_82Z's Avatar
if i can get OEM GM parts and it done for free, than im getting it done that way, plus its the seat belts, i want to be sure it is done right
Old Mar 14, 2008 | 12:29 PM
jw89camaro's Avatar
Car: 1989 I-Roc Z28
Axle/Gears: 3.45
wow!!! good thing i swaped out my 89 seatbelts for a set of 88
Old Mar 14, 2008 | 06:04 PM
89RS_82Z's Avatar
88 is still under the recall i think so you may not be in the clear
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
MORREALE5
Sep 13, 2015 09:01 PM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
