Changing Orange shifter and HVAC light to blue LED
Old Mar 14, 2008 | 09:15 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Ok, ive done some searching and a lot of research, but I still havent found my answer.
I curresntly have HVAC controls out of a transam in my camaro and they light up an orange color and so does my shifter plate with the stock bulb. If i change that bulb to say a blue LED, what color would it light up? will it still be orange or will it change at all? Does anyone have pics of of these with different color bulbs? I know with the white hvac and shifter it will change but I dont know about the orange color. anyone tried it or anything
Old Mar 15, 2008 | 01:13 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Changing Orange shifter and HVAC light to blue LED
I'm pretty sure in the shifter, there is a orange under layer that makes it light up orange. I think thats what it was when I removed it from mine. Not sure about the HVAC, good luck...
Old Mar 16, 2008 | 06:46 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The orange is between the white you see on top & the black coating on the underside of the shift indicator lense.On the HVAC the orange is applied in a similar manner.Changing the bulb wont really get rid of the orange color.On the camaro HVAC though there is no orange coating only blue & only white on the early(pre 90 i think)shift indicator.
Attached Thumbnails Changing Orange shifter and HVAC light to blue LED-copy-zzzrf.jpg
camaro11j
Sep 19, 2018 08:49 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 19, 2015 01:36 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
