Hatch pulldown unit is loose
Old Apr 1, 2008 | 01:11 AM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
I think it finally came off of the tracks. I had trouble getting the hatch to secure, and noticed that i can grab the assembly and wiggle it around significantly. The unit still moves up and down, but the whole assembly is loose and I had a really tough time getting it lined up just so, so it would grab my hatch and pull it down.
This is on a 1989 TTA, by the way.
Old Apr 1, 2008 | 01:56 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Hatch pulldown unit is loose
The nylon sliders are probably worn out. If you look where the motor rides in the tracks, you will see nylon bushings. If that turns out to be the problem, you can get new ones from top down solutions:
http://www.top-downsolutions.com/pro...809f03e97593b1
Old Apr 4, 2008 | 01:49 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yep, what he said.
Lon
Old Apr 5, 2008 | 03:01 AM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Okay, I wasn't sure if it was the tracks or not - good thing they offer a warranty...
Old Apr 5, 2008 | 06:52 AM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
It may have broken the motor housing also. I just fixed mine and it was two problems, the slider busings and the motor housing. Top down has a kit that has everything you need to fix it right, $72.50 1986-91 Camaro or Firebird hatch pull-down repair kit TDS 204040 .
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
punkmaster98
Sep 30, 2015 11:01 AM
!CamaroDave
Convertibles
Sep 17, 2015 12:53 AM
