4th gen window switches.
Old Apr 4, 2008 | 11:55 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Between the cost and rarity of a 3rd gen window switches I'm considering alternatives. Does anyone know if 4th gen window switches will work in 3rd gen cars? same harness and will it be a clean install?
Old Apr 5, 2008 | 02:09 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: 4th gen window switches.
no one know?
Old Apr 5, 2008 | 03:37 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
dont know about the 4th gen switches...but the 3rd gen switches are available new from classic industries (Part# G6899 ), bout $17 ea.
or about 2 bucks at the JY
Old Jan 30, 2011 | 11:56 AM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Modification is required, the 4th gen cars used a similar wiring setup for the windows but it will not be plug n play. You will need to graft in a 4th gen switch plug (single style for each if using the 3rd gen switch location or one single and one double if moving the switches to the doors). There is also a power window control module (allows auto down feature) and a retained accessory power module (allows 10 min of power after key is turned off to power accessories). These are optional, and would be a little trickier to install, but not impossible.
Old Jan 30, 2011 | 12:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Old Jan 30, 2011 | 12:31 PM
Just to clarify, the 3rd gen and 4th gen switches can be made to work on either harness, I temporarily grafted my 3rd gen switches on my 1994 wiring harness until I found some switches in the junkyard, and they do work. It's not ideal, and it took a little studying of the wiring diagrams.
69 Six Pack
Oct 5, 2015 07:51 PM
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
