Plastic Dash part 85 --- 91
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Axle/Gears: Uh, Haven't investigated this yet
Is the Main Dash part, The biigg plastic peice. Is it interchangable from year to year. There is a guy that has an 91 dash for sale. My 1985 is cracked in the center. If I get this will All of my Guages/Switch/Accesories fit it? Will my Center Console fit it also? I want everything to line up nicely.
Car: 91 Camaro RS
Engine: 305 TBI *355 Coming Soon*
Transmission: 700R4 *T56 Coming Soon*
Axle/Gears: 323
Re: Plastic Dash part 85 --- 91
It seems like you want the whole dash. If thats the case then no because anything pre 90 has manual gauges, and everything post 90 has electronic gauges and the two are not compatible.
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
I take it the back of the dash isn't cut out for speedo cable and stuff. I'm planning on still using my 85 guages as the new dash dosn't come with any.
This is a pic of what I'm looking at buying.
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
the Camaro changed dash style in 1990. Your guages will not fit the 1991 dash at all, it requires a completely different shaped guage cluster. Your guages will fit inside a 1982-1989 camaro dash and be functionally interchangeable. I'm not sure if small changes were made during that time.
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
i have a full 90-92 style dash with a gauge cluster and the wiring for sale. pm me if you want more info on it.
Car: 1989 IROC 406 SBC (2012 Fusion)
Engine: 406 Chevy-World Sportsman heads
Transmission: 700R4 B&M, Redline clutches, 2800
Axle/Gears: Australian 9 bolt,I think 3.73
I have a 89 Iroc needing a whole interior repair/redone. In the garage sits a 1990 RS with all the interior in good condition, except the dashpad and seats. I am aware SOME of the dash changed from 89 to 90. What should I be aware of, as far as differences between the 89 and 1990 interior, when I exchange parts? Thanks.
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
The '90 and later dashes, apart from the obvious differences, also use different mounts on the body. So it's not a direct bolt in. But if you changed the mounts you could probably make it work. I've also been looking for a perfect 84-89 dash also. No luck here either.
1992 Trans Am
May 10, 2023 07:19 PM
1984, 1987, 91, camaro, camarotransam, cluster, compatibility, dash, dashboard, guage, interchangeable, pad, repair, sell, wiring
