Mounting aftermarket sail panels?
Old May 5, 2008 | 11:37 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
I have new sail panels I ordered from Paddock. There is nothing on the back side to mount them. No hooks, no velcro. The coat hook screw alone holds them in pretty well but I'm thinking double sided tape to hold the curve better. What have other people used?
Hind sight: recovering the old ones would have been less hassle.
Old May 5, 2008 | 05:21 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Mounting aftermarket sail panels?
Do you still have the old ones? If so, just pull the clips off those, and glue them to the backs of the new ones. Otherwise, vel-cro would probably work well. I wouldn't use double sided tape, just in case you want to remove them later (like to get at the speakers) without destroying them.
Old May 6, 2008 | 11:26 AM
ACCLR8N's Avatar
Have you glued the metal hooks to the boards before?
Old May 7, 2008 | 11:54 AM
Rva's Avatar
Rva
Car: 1984 z28 camaro
i hear most people use velcro, and it sounds like a good idea to me
Old May 7, 2008 | 08:55 PM
ACCLR8N's Avatar
I picked up "industrial strength velcro" today. Worked fine.
Old May 8, 2008 | 10:12 AM
Rva's Avatar
Rva
good
Old Jun 8, 2008 | 11:48 AM
83Chevy__Camaro's Avatar
aftermarket ones are garbage i threw the ones i bought away i couldnt believe they actually thought velcro was better to replace the stock setup
Old Jun 8, 2008 | 03:27 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
i just fixed mine today AGAIN the velcor will end up coming off after a while( 3 months for me) i super glued both side of the velcro and just hoping for now, after market ones are complete trash
Old Jun 9, 2008 | 06:04 AM
ACCLR8N's Avatar
Mine isn't holding very well either. Every time I think to look at it, I have to push it back in.
Old Jun 10, 2008 | 09:15 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Mine were dirty and I pulled the material off the board and put them in the washer. Cleaned up real good and instead of the staples I used velcro to mount them to the board again. My 89 used a board but my 92's were mounted to a plastic back which sucked and didnt fit as good.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
