Need Horn Fixed To Pass Inspection
Car: 1991 Trans Am GTA
Axle/Gears: Yukon 3.73 posi
So just as the title says, In the state of maine, the horn needs to work to pass safety inspection. It is a 1991 Trans Am GTA and the center piece is peeling back at the corners like a lot of our cars.
I assume that the ceneter piece peeling back is the cause of the horn malfunctioning so how would I go about removing/ replacing it... can I do that? There are also not any salvage yards around here si I'm not sure where I would get the piece if it is replaceable.
Any suggestions?
Pics if requested.
Any suggestions?
Pics if requested.
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: Need Horn Fixed To Pass Inspection
You have checked the fuse right?
If you just need a quick workaround you could get a push button type switch and wire it to send ground to the black wire in the steering column harness. Not the ignition harness, the smaller one that sits on top of the column.
A valet switch from an alarm would do the trick just fine. One wire goes to ground, the other goes to that black wire. Run the wire up to the back of the steering wheel, and possibly even slip it under that peeling back corner. I'm not suggesting this as a permanent fix, just a workaround to get you through the inspection.
Last edited by titan; May 5, 2008 at 06:49 PM. Reason: specifics about which harness added.
how would I go about taking the big square centerpiece off the steering wheel to get to these wires?
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Four screws on the back side hold the center piece on. When you get it off, you may find the horn switches behind it have deteriorated and are causing your problem. The switches and harness are available at sites like Hawks and are easily replaced. My 91 did the same thing and I think the part was about $15.
Good luck.
Good luck.
Car: 1991 RS Hardtop
Axle/Gears: 3:23
Not to hi-jack your thread but i have the same problem with my 91 camaro. The fuse is fine, the horn works when hard wired... but it doesn't work when i push the two buttons on the steering wheel... has anyone had this issue with their 91 camaro too?
yeah...i have the same exact problem. only thing is i cant find the horn on any of my wiring diagrams...so its hard to put a new switch in since i dont know the wire colors. if anyone could help me out and lemme know:
1) where the actual horn is located
2) what color the wire from the wheel to the horn is
Car: '92 Firebird
Engine: 3.1L V6 MFI
Transmission: Manual
2) The wire doesn't run directly from the horn button to the horn, it goes through a relay. But the common wire around there connecting the two horns is green.
Had same problem with a car years ago, wasnt a problem till inspection. Until you can properly fix it go to a parts store and buy a horn button and mount near steering wheel. Run 2 wires and your ready for inspection. Then you can take your time fixing horn right.
Car: 1991 RS Camaro
Engine: 305 5.0L V8 EFI
Transmission: Automatic
I'm having the same issue where my horn wont work. I'm going to look at the fuses today but in the fuse box I don't have a diagram. So could someone tell me which fuse it is for the horn?
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I think it's the #11 fuse for accessories. Covers horn relay, dome light, third brake light, door locks, lighter, etc. You should be able to search on here and find a diagram of the fuse box. If not, it should be the third from the left on the third row back or away from you from under the wheel. If none of these other things work or if the fuse blows upon a new one being replaced, suspect the lighter socket that grounds out from age or something. Just disconnect it and try a new fuse. Otherwise your switch buttons could easily be broken under the air bag. Remove it to find out being sure to unhook the battery first.
Happy hunting
Henry
Happy hunting
Henry
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Not sure how accurate my memory is so went on the internet and dug this up. Should be plenty to answer some questions
https://www.google.com/?gws_rd=ssl#q...se+box+diagram
Good luck
Middle row red box around it and others. Right location , but tagged CTSY(courtesy)
Good luck
Axle/Gears: 3.45, 3.27, 3.27
Remove the 4 torx screws that hold the air bag in place. Then check out the condition of the horn buttons mounted on either side of the steering wheel. It is common for them to crack and break. The center spring-loaded portion pops out if that happens.
I have some good used ones on my web site.
Lon Salgren
Lon Salgren
