replacing the wiper lever, hard?
Old May 12, 2008 | 12:27 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
hey guys. my wiper switch will only consistantly work when it's on the full throttle position, i have a fully working one with busted plastic in my parts car, how hard is it to disassemble the column and the wiper stalk and replace it? should i just try and get a column?
my parts car is an 87 gta, and the driver s an 85 t/a. thank for the help in advance.
Old May 12, 2008 | 08:58 AM
NobleHdwe's Avatar
Re: replacing the wiper lever, hard?
It's not that hard, just have patience. Do a search on here about the disassembly of the column for loose steering wheel and such. There is one on here, can't remember who posted it, but they have a real good diagram that would be really helpful. Once you tear into it though it's pretty easy.
Old May 12, 2008 | 10:08 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
thanks, i'll go look for it.
Old May 12, 2008 | 10:59 AM
NobleHdwe's Avatar
No prob. If I can be of more help just let me know.
Old May 12, 2008 | 12:03 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
i found the thread about tightening the tilt columns and it explained alot of what i have to do, looks like i won't have to go very far into the column to get the wiper stalk undone, i'll just have to peice together one good wiper stalk cause one works well and has busted plastic and the other is vice versa. looks like a lil weekend project.
Old May 13, 2008 | 08:10 PM
NobleHdwe's Avatar
Yeah you don't have to go too far, just enough to get to the signal cancelling switch. Yeah it shouldn't take you that long to do it. The first time is always longer, but after that you can do it no problems.
Old May 14, 2008 | 10:43 AM
banker's Avatar
Car: 87 TA
Axle/Gears: LSD
Are you certain it's the wiper stalk causing the problems, I had similar symptoms which was due to a duff connector to the wiper motor control unit on the firewall.
You never know, could be worth checking before disassembly
Frozer!!!
Jan 19, 2024 04:55 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
db057
Aug 22, 2015 08:17 PM
slade5612
Aug 11, 2015 07:19 PM
