v6 to v8 instrument gauges
Old Jun 10, 2008 | 08:09 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well, now, that i already payed for this new gauge cluster, i think i messed up because on the way home i remembered this new one is out of a v6 tpi ,i don't think tpi or not matters. is there anyway to make this one work? my old one just went crazy all the time.
Old Jun 10, 2008 | 09:44 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: v6 to v8 instrument gauges
depending on the year (speedo cable or elec) it would work, only problem is, your tach would be setup for a v6, not v8, so you might see a 'small' increase in rpms LOL (your tach will be way off)
Old Jun 10, 2008 | 09:55 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
Many of the V6 gauge clusters had oil light and not an oil gauge which would mean changing out the oil pressure sender if thats the case with this one.
Old Jun 11, 2008 | 03:29 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
no oil light ,gauge, can i just switch tachs?
Old Jun 11, 2008 | 10:12 PM
That should work, unless there's something actually wrong with the old tach. You could conceivably swap all the gauges if you wanted but its probably not nessecary.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
