turn signal lever swap
Old Jun 17, 2008 | 08:33 PM
davr89's Avatar
Car: 2004 Silverado SS
Engine: 6.0L LQ9
Axle/Gears: 4.10 AWD
i just bought my 1988 gta, and the turn signal lever looks like crap and the guy gave me a new one from gm to swap in, so my question is, how?
Old Jun 17, 2008 | 09:26 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: turn signal lever swap
Grab it by the base (the part of it that doesnt rotate), push in, and turn CCW about 1/4 turn. It should then pull out, it might take a little wiggling though. The wire for it runs down the column, and plugs in under the dash. Unplug it, pull the old wire out, and fish the new wire down the column, then install the new one.
Old Jun 24, 2008 | 02:43 PM
davr89's Avatar
Engine: 6.0L LQ9
thats it? seriously!?! i was thinking i would need to take the steering column apart similar to when i had to tighten it.
Old Jun 24, 2008 | 03:57 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Just be easy and dont strip out the little tit in the column that it sets in.
Old Jul 14, 2008 | 09:36 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
same procedure on camaros. i cant seem to get it out. and also there is no part on the lever that dosent rotate becuase of the intermittent wiper option?? any ideas
Old Jul 16, 2008 | 11:42 PM
GadeXTrigger's Avatar
Car: 91 Camaro
Engine: 5.7Fl V8 350 tpi
Transmission: 700R4 Automatic
In my camaro it takes some force to make the turn signal go down or up not like u have to pull on it but there is some resistance on it is that normal?
Old Jul 17, 2008 | 12:41 AM
HairHag's Avatar
Car: '88 Camaro
Engine: 305 TBI
And is this the procedure for fixing a stuck turn signal? As in, one where the stalk doesn't automatically return when steered straight.
Old Jul 17, 2008 | 12:50 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I think thats actually part of the switch inside the steering column. This is for swapping out the lever itself...
Old Jul 20, 2008 | 11:18 PM
Engine: 350TPI
IS THE PROCEDURE THE SAME ON CAMAROS AS TRANS AMS is what im asking because ive been told i have to remove the lock plate assembly as well
Old Jul 21, 2008 | 01:39 AM
HCR13's Avatar
Car: 1987 Trans Am
It should be the same procedure for both f-bodies. Both swapping out the lever and swapping out the switch the lever controls inside the column...
Fronzizzle
Mar 18, 2019 08:29 PM
Caspar
Jun 19, 2016 11:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
