turn signal and hazard switch
Old Jul 9, 2008 | 09:12 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
im thinking about replacing both of them. for the turn signla/cruise switch ive been told i have to take the lock plate out. others say i need to push the switch in and rotate it ccw and it will pop out. which one?? also how do i replace the hazard switch ****??
Old Jul 9, 2008 | 09:41 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: turn signal and hazard switch
The hazard is part of the turn signal switch (inside the column, not the multi-function lever). I just replaced mine a few weeks ago and the hardest part was actually feeding the wires down the column. I don't have much mechanic experience and I was able to do it.
Here's my thread on it, sorry I deleted the pics.
https://www.thirdgen.org/forums/elec...al-switch.html
Old Jul 9, 2008 | 09:46 PM
Engine: 350TPI
maybe fire birds and camaros differ there but outside of my steering column theres a a pull button on the bottom for hazard lights. i wanna replace the **** with the painted "HAZARD" lettering on it. also my multi functional turn signal/wipers/cruise/brights lever i wanna replace that to.
Old Jul 9, 2008 | 09:57 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Oh okay, yours is not broken, you're changing it for looks? In that case, the new turnsignal switch does not come with a new ****, I had to reuse my old one. I haven't replaced the multifunction lever so I'm not sure about it. I heard you turn it clockwise (toward the seat) and pull out, but like the switch, feeding the wire down the column is the hardest part.
Old Jul 9, 2008 | 10:03 PM
Engine: 350TPI
my apology. i worded that wrong. so yeah i should just push that in turn it ccw any idea on the hazard ****??
Old Jul 9, 2008 | 11:51 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
The hazard **** just has a tiny philips head screw in the center of it. That's all that holds it on.
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
