Interior Roof Fabric Sagging Need Fix Plz
Old Jul 16, 2008 | 06:13 PM
GadeXTrigger's Avatar
Car: 91 Camaro
Engine: 5.7Fl V8 350 tpi
Transmission: 700R4 Automatic
I am new to this site and msg boards but anyway
I am the owner of a 92 Camaro and the interior roof fabric is sagging
and i was wondering what i would need to fix it and how much it would cost
Old Jul 16, 2008 | 06:20 PM
jim91gta's Avatar
Car: 1991 GTA
Engine: 5.7
Re: Interior Roof Fabric Sagging Need Fix Plz
When mine sagged I took it out of car
removed headliner
used brush to get old debris off
went to Joann fabrics and got some great looking microfiber material for $15
got the 3M adhesive $10
sprayed adhesive on the headliner foam and microfiber (slowly as once it sticks it is there for good)
it has been up for over 1yr.
I live in florida so the heat and humidity has not affected it at all.
I will be using the same material on pillars and rebuilding seats with it.
Hope this helps
Old Jul 16, 2008 | 08:58 PM
Car: 91 Camaro
The microfiber material is the stuff that is sagging? and how do i take the headliner out? but yes this was very helpfull.
Old Jul 16, 2008 | 09:06 PM
xChAoSx's Avatar
Car: 1987 Firebird
Thus ressor's coil, and to gruntry life; and lose bourns, and arrows of die, the rub; forthy to takes, puzzles the nation. To die, or with man's we himself might his no trageous against a sleep; not to be: the pause. Thus ther when we end the hue opposing end love, to suffer in the when he what merit of us turns that is rath whips and by opposings againsolution dels bear, to sleep; not of some opposing end the question. To discove, and the law's the dread office, to beart-ache rub; for no mome of de
Old Jul 16, 2008 | 10:24 PM
speedflea's Avatar
Just got home from the store with all the materials. Will be tackling mine tomorrow.
As for the question of how to remove the whole head liner,
remove the three screws in each sunvisor.
remove the dome light fixture.
remove the two sail panels in the back seat where the rear stereo speakers are.
take the plastic trim piece off along the top of the rear hatch.
There is a plastic guide piece where the seatbelts go in to the headliner, remove them carefully. they just snap in there.
then carefully, oh so very carefully remove the entire interior top of the car. Carefully cause its just paper molded to shape. try not to break it.
Mine is a T top so I pulled the tops out to make it easier to remove, Don't know how much of a PITA it might be with a solid roof.
After you get it out just pull the existing fabric off of it and put some new stuff on it using 3M77 or similar and reinstall in car.
Old Jul 16, 2008 | 10:29 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Speedflea you redid yours in your t-top. did the microfiber fabric fit the curves real nice? thanks in advance
Old Jul 16, 2008 | 11:33 PM
Car: 91 Camaro
whoa thknx that is very detailed ima use that to do it 2marrow
Old Jul 17, 2008 | 06:16 AM
speedflea's Avatar
I didn't do it yet. All I did was pull the top out and buy the stuff. Should have it done either today or tomorrow. will try to post pics of the end results if you'd like
Old Jul 17, 2008 | 07:27 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I have a tech article that shows you step by step how to remove and reinstall a headliner:
http://www.iroczone.com/technical/headliner
Old Jul 17, 2008 | 09:32 AM
Car: 91 Camaro
whoa very very helpful just what i needed to know
colton_carlson
Mar 8, 2019 12:21 PM
diana227vegas
Jul 8, 2016 12:27 AM
86IROC112
Apr 9, 2016 10:20 PM
inferno15
Aug 29, 2015 01:48 AM
