Door pannel removal
Old Jul 19, 2008 | 03:14 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Door pannel removal
pretty simple for someone who's done it before. How do I get the door pannel off my 92? Do I just need to take all the bolts out of the armrest then It'll lift out or is there more?
Old Jul 19, 2008 | 04:08 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
Re: Door pannel removal
unbolt the arm rest. take off the door lock switch panel there is a bolt behind it that has to come out. slide out the door cups. use a door trim stud tool to pry out all the studs behind the card board panel. once there all loose remove 3 clips from the top door rail by pulling up and lightly prying the clips out. it should slide right off at this point. while you back there lube the window tracks and door locking mechanism as so you dont have to take the panel off again in the near future for those reasons. yours may differ being that its a firebird but it should be realitivley the same. youll have to cross those different bridges when you come to them
Old Jul 21, 2008 | 06:57 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
To add to the above, if you have crank windows there is a metal pin behind the ****, pliers or the special tool will prove useful for this.
Old Aug 6, 2008 | 01:44 PM
miketysonwins's Avatar
Be careful not to take out too many screws after you get the panel off or your window mechanism can fall out of place lol.
Old Aug 8, 2008 | 12:21 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
"White lithium spray lube" Is the best for lubing the regulator. It's what they use at the factory and it is waterproof and dos'nt attract dirt. Just be careful what you get it on, it dosent wash off of fabric!!! It's available at most parts stores.
Old Aug 12, 2008 | 03:28 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Ok, I'm guessing these's a screw behind the little pastic bird on my door, but is that black circle in the handle well a screw too?
And I dont get what you do with the black palstic top part. I tried to just pull it out or up but didn't want to break it.
Old Aug 12, 2008 | 03:37 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
put your window down, and then with the door open, push the black upper armrest peice forward, towards the outside of the car, and up all in one motion. make sure you have all the clips in the door panel popped out or else that will stop the panel from moving. Just make sure not to get frustrated when doing it and take your time so you dont break the clips in the back of that top peice. hope i helped.
Old Aug 14, 2008 | 08:03 PM
evans87's Avatar
Car: 1987 Iroc Convertible
Engine: Bone Stock, 66,000
Transmission: 5 speed
Im still confused, dont have that much experience. when you say push it towards the outside, what do you mean? If I open the door and I am now facing the panel, do I push it to the left or to the right while pushing up?
Old Aug 14, 2008 | 08:20 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
I think you push up and out if you are facing the panel.
My question is (might help you too), how do you get the little plastic clip with the bird logo on it off without scarring or breaking it? I jacked the piece on my parts car up really good with a flat screwdriver.
Also, did someone say to take all the panel clips out BEFORE trying to remove the top piece? That might be why I couldn't get mine off.
Old Aug 15, 2008 | 01:07 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
There is an easier way to get the clips holding black top part free I discovered. Once you've removed all the screws, handles and clips previously mentioned, lift up on the panel from the bottom while also pulling it inward. Then give the the panel a bump toward the rear of the door. It will slide to the rear and clear the ramps that the top clips are engaged on and come off easily. The top clips had been frustrating for me to remove at times previously before I learned this trick.
Lon
Old Aug 16, 2008 | 10:34 AM
Car: 1986 Iroc-Z
Lon
your not kidding, ive broken many top rails because of this. Taking the door panels/top rails off is still easier than say removing a hardtop's a pillar
Old Aug 16, 2008 | 11:17 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Lon
If that will work with the window up there's a lot of door panels I could select from at the JY. At least without lugging a battery in, which I've done.
Old Aug 17, 2008 | 05:47 AM
I broke a lot of top rails at the junkyard before I figured it out. Go to a junkyard and practice there.....
Old Apr 30, 2013 | 07:49 PM
Van Nuys born's Avatar
Car: 4/89 IROC Z28 G92 -
Engine: LB9 TPI
Axle/Gears: 3.45
I found this post in a search for door pannel removal.
I was going to replace my driver side door handle as the spring that keeps tention on it it is loose.
Where can I get the tool to pop the fasteners loose... mentioned in the 2nd post ?
And any updates to the door pannel removal ?
ktthecarguy
Jul 5, 2020 11:46 AM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
