98-02 steering wheel w/controls
Old Aug 20, 2008 | 11:50 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
How would I go about hooking up the radio controls from a 98-02 z28 steering wheel into a 92 camaro. I wanna update the look of the wheel yet have more functionality with it too
Old Aug 25, 2008 | 03:36 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: 98-02 steering wheel w/controls
i as on a mission to do this with my dash swap since i am using a factory cd player.
i said the hell with it.
im not sure if you need the steering column out of the car, but you will need the steering wheel, cd player, cable, and i think there is a grey type ring that goes behind the steering wheel onto the column... i never tried to set it into the 3rd gen column, but that itself may be the issue.
good luck.
Old Aug 25, 2008 | 08:48 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
IMO the easiest way would be to get the whole column and wheel. I have a 4th gen cd player in my car that plugged right in. I believe it's only two wires that would need to be run from the column to the back of the radio.
Old Aug 26, 2008 | 12:01 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
i dont think the 4th gen one fits in there. believe it sits at a different angle
Old Aug 26, 2008 | 09:12 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
I have a 98 camaro steering wheel on my 87 iroc, it's the kind without the controls. Works great!
Old Aug 26, 2008 | 08:34 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
it does sit different. where i dont know for sure.
i was going to use a 4th gen tilt lever... and that didnt work. put the stocker back on.
its got a bend in it and was right up to the bezel. id say the 4th gen column may be longer?
Old Aug 26, 2008 | 08:53 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
keep in mind the 4th gen column also bolts up to a rack and pinion unit instead of a steering box like a 3rd gen, it would probably require quite a bit of modification to make it work.
Old Aug 26, 2008 | 09:19 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
ive never looked at one side by side, but GM doesnt waste money unless they need to. the steering damper may have the same double D shaft as earlier models. pretty standard.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
