Shift Knob
Old Sep 29, 2008 | 09:40 PM
Norm_Neal's Avatar
Car: 1991 RS
Shift ****
I have read a good many old posts on this but want to be crystal clear. I have a 91 RS 5 speed and want to replace the black plastic shift **** w/ something that looks a little better. One of the posts suggested using vice grips and channel locks, and something to break it free, is this correct? Also I read it has metric threads, short of cutting/retapping is there anything out there in the Hurst/ B&M lines that work? Thanks
Old Sep 29, 2008 | 10:17 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: Shift ****
Which shifter do you have? Is it the round ball or the leather shifter? I doubt you will need channel locks or vice grips. Both factory ***** are held on with clips that are easily removed once we know the type you have. A 91 should have a C clip in the front that is pulled out with needle nose plyers or a flat head screw driver. Post a picture.
Old Sep 29, 2008 | 10:28 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Re: Shift ****
He has a 5 speed, so it should just unscrew. Its going to be really tough, but it should break free with some muscle.
I found some shifter ***** for our cars at a swap meet (16mm x 1.5) and he even had 5 speed patterns. They are around.
Old Sep 29, 2008 | 10:33 PM
Axle/Gears: Posi
Re: Shift ****
Duh!...I missed that part. Yeah he has to un screw it. Good luck with that. Man up...
Old Sep 30, 2008 | 12:50 AM
Norm_Neal's Avatar
Car: 1991 RS
Re: Shift ****
Guys thanks for the replys. Funny story, last time I tried removing it(17 years ago) I guess the threadlock/loctite the factory put on it was fresh. When I came home from work tonite and tried it, it unscrewed like opening a coke, imagine that.
Old Sep 30, 2008 | 03:34 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: Shift ****
Here's a pic of my Hurst shifter (the shifter handle will fit on the stock shifter)....JEGS, Summit, etc.
Last edited by 89transam*pearl; Sep 30, 2008 at 03:43 AM. Reason: no pic attachment
Old Sep 30, 2008 | 07:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Shift ****
The B&M Hammer shifter is a direct fit. Check my Car Details below for a pic.
JamesC
Old Sep 30, 2008 | 02:55 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Re: Shift ****
yep, the 5 speed **** just unscrews. i think the auto round **** has a circlip under the button. i just got a new manual **** from GM, was like $5 or something.
Old Sep 30, 2008 | 03:02 PM
FUNIROC's Avatar
Car: 1989 IROC
Re: Shift ****
They do make a black leather shift **** that would make a great upgrade. They cost around $40 shipped.
Old Sep 30, 2008 | 05:22 PM
Norm_Neal's Avatar
Car: 1991 RS
Re: Shift ****
Thanks for all the replies!
Night rider327
Feb 25, 2016 09:50 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
