How do i reduce top dash rattle?
Old Oct 11, 2008 | 12:08 PM
3rdGenIrocZ's Avatar
Everytime i get on the highway around 60 or more the top pad starts shakeing up and down, theres a part on hawks for the frame of your car that says it reduces it but honestly a solid hunk of metal wont help it so any ideas?
Old Oct 11, 2008 | 12:17 PM
Stephen's Avatar
Car: 87 GTA
Re: How do i reduce top dash rattle?
Just the dash pad? Or is it being transmitted through the car from something else? Tire balance? Driveshaft balance? Bad engine/tranny mounts?
Is your pad dash screwed down? Mine has ZERO screws holding it own & vibrates none at all.
Old Oct 11, 2008 | 12:19 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Its an old car, deal with it.
If it really bothers you, just check to make sure everything is tight. Sub-Frame connectors will help, because they will make your car alot stiffer and it wont flex as much.
Old Oct 11, 2008 | 12:21 PM
Well i cant fix anything now its getting painted and ill get it next week. But i just got the front end suspension and alignmeant all redone so idk if that will help, and the dash pad is screwed down pretty darn good
Old Oct 12, 2008 | 07:25 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I've found that overtightening the screws will cause rattles and squeaks as there is no movement allowed. I learned to tighten all screws only so far.
If the car is still shaking after the front end rebuild and the tires are balanced correctly, check the driveshaft for balance.
Old Oct 12, 2008 | 09:43 AM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
"Its an old car, deal with it."
Old Oct 12, 2008 | 11:55 AM
kcb37's Avatar
You could try some padding under it.
But like Stephen said, I don't have a single screw in mine and it dosen't rattle, or move for that matter.
Well except that ontime at the track I grabed 3rd and the whole car jerked.
Slid back about 3 inches that time.
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
xxx3man`
Sep 23, 2015 10:37 PM
aaron7
Aug 26, 2015 09:45 AM
mustangman65_79
Aug 8, 2015 12:07 PM
