Help! Loose Tooth Steering Column Repair
Old Oct 22, 2008 | 12:08 AM
VEGASIROC's Avatar
Transmission: Manual
Hello,
So I started to re-assemble my steering column after tightening the 4 bolts that were buried. I'm having a problem with the Key Warning Buzzer Switch and Retaining Clip (I believe pictured below). Do both of these parts go together? If so how? If not, where does that Retaining Clip go? The clip fell out with all the moving around.
Any other help,pictures,and suggestions would be greatly appreciated.
Attached Thumbnails Help! Loose Tooth Steering Column Repair-housing.jpg   Help! Loose Tooth Steering Column Repair-buzzerswitch.jpg
Old Oct 22, 2008 | 03:48 PM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
Axle/Gears: stock axle
Re: Help! Loose Tooth Steering Column Repair
I just went thru the same thing. Yes they go together. I have attached a picture of how.
Attached Thumbnails Help! Loose Tooth Steering Column Repair-column-repair.jpg
Old Oct 22, 2008 | 04:11 PM
VEGASIROC's Avatar
Thank You very much. What manual is that out of? A lot cleaner than chiltons...
Old Oct 22, 2008 | 06:55 PM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
it is out of the shop manual for 88 z28s. I bought it off of ebay.
83 Crossfire TA
Jan 3, 2016 01:26 PM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
