Steering column removal on '91 RS
Old Oct 26, 2008 | 02:42 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Engine: 305 Crossfire
Axle/Gears: 3:23
I am taking out the steering column in my son's '91 RS and I came across this cable, does anyone know how I can take this cable off of the column in order to remove it? I'm getting it rebuilt, to many things wrong with it.
Attached Thumbnails Steering column removal on '91 RS-img00173.jpg   Steering column removal on '91 RS-img00174.jpg
Old Oct 26, 2008 | 03:45 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Axle/Gears: 3:23
Re: Steering column removal on '91 RS
Anyone ?? Please help, as this cable is holding me up from taking the column to the shop.
Old Oct 26, 2008 | 04:25 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
last month i swapped a 89 r/s standard shift column into my 88 s/c auto . mine was just a little different looking . cable runs to auto shifter , i forget what its called . any way you can just unbolt entire bracket with cable from column . dimmer sw. rod just slips out . you may have to re-adjust sw. when you re-install . no big deal , just try and set it to hear dimmer sw. click before tightening sw. bracket & raising column back up . hope this helps . good luck .
Old Oct 26, 2008 | 04:52 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Axle/Gears: 3:23
Awesome !! Thank you very much.
Old Oct 27, 2008 | 11:43 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Axle/Gears: 3:23
If I were to purchase another steering column from the wrecking yard, and reused my ignition switch out of my existing column onto the newly purchased one, would this work ? Also, can I bypass the VATS in my '91 RS with this schematic? : http://shbox.com/1/vats_bypass.jpg
Old Oct 28, 2008 | 08:03 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Axle/Gears: 3:23
Old Oct 28, 2008 | 08:12 PM
UNCLE TOM's Avatar
my 89 column had vats , when i put into my 88 i just cut the wires . it worked . oh well , i don't why the pics. you posted won't work . good luck .
Old Oct 29, 2008 | 11:49 AM
NobleHdwe's Avatar
That will work for the vats. That is how the previous owner did it on my car. They also make the plug in adapters that take care of that too. Not too expensive either. Might be an alternative if you ever wanted to have it in the future.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Oenone
Aug 29, 2015 07:54 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
