HVAC problems ASAP
Car: 85 IROC "SYNASTR-Z"
Engine: 355 SBC
Transmission: 700-r4
Axle/Gears: 3:73 disc brake
HVAC problems ASAP
Ok i had heat in my 87 t/a tpi. One day i turned it on and no heat just defroster i hit every button "digital dash" and it still was defroster plus even at 190 the air coming out isnt warm. Can someone tell me what to check? Its getting cold and i NEED heat. Thanks
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: HVAC problems ASAP
What a half-*** response.
On subject, I don't know if you vents in your car are vacuum or electronically operated so I wouldn't be much help there, but the cold air when engine warm has me a bit concerned.
If It's a digital dash then maybe the controls are just taking a vacation and not operating the vents or HVAC properly.
Heater core could possibly be plugged.
Also make sure you keep an eye on your water pump and engine temp. In my girlfriends old car we couldn't figure out why the heat would blow could unless it was turned down low, then a couple days later we found out it was a bad pump not properly circulating water through the engine and heatercore. Unfortunately she didn't know well enough to STOP DRIVING the car when the temp gauge was all the way on HOT and seized the engine.
I seriously doubt this is your problem though. If the car is a digital dash it sounds like something just shorted out.
Car: 1985 Z28
[quote=xflgkingpin;3951234]
Do us both a favor man, and excuse yourself from this thread.
You've done nothing so far but mock both the serious posts in it.
Yes it was no **** that the space heater response was just a joke but you know what, it was rude that it was the only thing you posted to this guy who has a serious problem with winter approaching. It's a bit difficult to drive a car with the windows all fogged up. And the "Your welcome" line only added insult to injury. Had it been a quip thrown in after a possible solution, then everyone would have been laughing.
You know what the sad part is? I'd be willing to bet you know more about these cars than I do, but your doing nothing but being a smart-*** and I'm trying to help the guy. That's pathetic...
Put the smilies away BTW. They don't make you look cute contrary to popular belief.
Car: 1985 Z28
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
There's a vacuum line under the hood that goes to the HVAC vent doors. It goes from the back of the plenum into the big wiring harness bundle behind the engine, on the passenger side. It should be pretty easy to spot, and should have a big round thing (one-way valve) inline with it.
When you change between defrost/vent/floor, there's a little flapper door in the air ducting that controls which vents the air comes out of. It's moved by a vacuum servo, which gets its vacuum from the vaccum line mentioned above. On the digital dash, there's also another vaccuum operated door that selects between cold (air through the A/C evaporator) and warm (air through the heater core). On the standard HVAC controls, the temperature door is controlled via a cable. To make things more complicated, the digital dash uses an electronic box under the dash to route vacuum, instead of the HVAC controls themselves like the normal setup.
Since both vacuum doors are not working, it's probably related to that vacuum line under the hood, I would start looking there first. Make sure it's connected, and not cracked/broken.
Engine: 355 SBC
well thanks for most of the help, anyways under the hood i replaced that diverter vacuum thing and checked the lines "actually replaced them all with hard line" any ways still didnt help. And yes it digital dash. So this electronic thing is located where? and could the switch control thing just not be sending the right signal? I need help fast.
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7L TPI 350
Axle/Gears: 2:73
My 87 GTA has electronic dash, when I slide temp control to cold the air stays warm, I slide it to hot it don't get hotter! It appears to be stuck in the middle, what would cause this? My vent selector works fine accept max(recirculate) it don't recirculate however the temp switches to full cold if I select a different mode the temp goes back to middle, I believe this means the motors are working, could it be the head unit? This head unit is impossible to find in the junk yard the only other car it was used in was the Cadillac Cimarron and I can't find 1 of them either, I'm thinking about trying the auto HVAC head unit from an SSE Bonneville any ideas?!
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
